Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
How do i set the voicemail on my uniden 6.0 cordless phone
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
    An expert that gotĀ 20 achievements.
  • Uniden Master
  • 102,366 Answers
Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Nov 29, 2012
  • kakima Nov 29, 2012
  • 218 Answers
SOURCE: Need an owner's manual for Uniden EZ1996 Cordless Phone
Here it is.
http://www.uniden.com/pdf/EZI996om.pdf
Posted on Dec 28, 2008
SOURCE: How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Posted on Feb 05, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
consultel1
  • 860 Answers
SOURCE: I have a uniden cordless phone model tru9480-3
With the phone in standby, press and hold [dnd] on the base. You will hear a confirmation tone and the [dnd] LED will go out.
Posted on Sep 20, 2009
Testimonial: "Thanks IT Worked"
SOURCE: How do I completely reset, and remove all settings
When I try to us my phone to make a call it says connecting there is no dial tone then is says unavailable
Posted on Feb 13, 2010
Model 1260 phohe,voicemail set up not on instructions
The Uniden 1260 isn't a voicemail system. To setup your voicemail system, please refer to the documentation for that system. If you're using the voicemail system provided by your telephone service provider, please contact them for instructions.
Jan 31, 2013 | Uniden Cordless Phone
The red light flashes that I have a message but I can't remember my password and I can't get the messages on the handset can you help with password?
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jan 03, 2013 | Uniden Cordless Phone
How do i set up voicemail?
You need to contact your telephone company for instructions on setting up and using their voicemail system. The Uniden D1660 doesn't record voicemail, though it can tell you when you have voicemail waiting.
You may download the D1660 manual here.
Dec 05, 2011 | Uniden D1660 Cordless Phone
Setup voicemail dect 6
you can contact the service provider.......
Oct 24, 2011 | Uniden DECT 6.0 Cordless Phone ID
How can i set the voicemail on uniden phone?
Since you declined to specify the model of your Uniden cordless phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Aug 20, 2011 | Uniden Cordless Phone
I would like to set my phone to ring up to 6 times instead of 2 rings then rolling over to voicemail.
The procedure for changing the ring count varies from model to model. Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Apr 12, 2011 | Uniden Cordless Phone
How do i set up the voicemail for the cordless
I can answer the phone but they cannot hear me speak.
Sep 01, 2009 | Uniden Cordless Phone
How do i set up the voicemail on a uniden 6.0
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Sep 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
How to set up voicemail?
I don't feel I should have to pay for some advice after I have paid for your machine.
May 19, 2009 | Uniden Handset/Charger Unit for UnidenĀ®...
Changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Feb 14, 2008 | Uniden Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
170 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
