Question about RCA OPAL M4001 MP3 Player
Won't turn on!!
Mp3 player was working fine until i plugged it into a separate computer through USB port. Now it won't turn on. I know it has a charge because when it is plugged into my computer I can feel it get warm over time. What should I do?
I had a similar problem. Holding the play button does not work to start it, but pressing it repeatedly and quickly turns it on. Might be the same for you?
Posted on Mar 29, 2008
SOURCE:
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Dec 11, 2012 | Philips Gogear Vibe 8gb Mp3 Mp4 Video...
Coby touch screen mp3 won't plug into anything
I use one of my other usb cords for my amazon and it works fine
Sep 23, 2012 | Coby MP828 MP3 Player
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    I bought a sylvania mp3 smpk4083 mp3 player and it orgianlly worked with my computer, but now when I connect it to my computer it turns on my player, but won't be regonized by my computer? How do
    Same thing happened to me with an IPOD. When I plugged it in to one of my USB ports, it ******** up all the USB ports. I suggest reinstalling the drivers for your USB Ports. Then install the software that came with your MP3 Player before replugging it in. Good luck :)
    Apr 01, 2012 | Sylvania SMPK4083 Digital Media Player
    My onxy mp3 player won't charge despite being plugged into my USB port for hours
    If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
    Jul 13, 2011 | Mach Speed TRIO Onyx MP3 Player
    My Sansa M250 is only 1 month old and won't recognize Music folders now when I plug it in. My PC does recognize the device but now it only shows Audible, Config and Record. Before it showed playlist,...
    reset the device to factory defaults thats it....
    check your usb ports are working properly in not i recommend to re instal the usb device drivers also
    Jun 27, 2011 | SanDisk Sansa m250 MP3 Player
    Noggin
    the player has to be connected to computer via USB cord one end goes into the mp3 or mp4 and the other goes into the usb port after it has charged to turn it on u have to hold the menu button down/ Thats how mine work Does anyone know how to add videos I have added pictures which looks beautiful.
    Feb 19, 2008 | iLO (2 GB) MP3 Player
    Recharging mp3
    Whenever the PD-6070 is connected to a PC, it will charge. The battery indicator on the OLED screen will slowly fill over and over as it is charging. When the charging is complete, the battery indicator will stay filled.
    Jan 18, 2008 | MyMusix PD-6070 MP3 Player
    Computer won´t recognize my player
    format the player from the player ( set-system menu) not from the computer. pull the battery from the player and leave it out for 15 minutes.
    reboot your computer. put the battery back in the player.
    plug it into the usb port on the computer. worked for me
    Oct 19, 2007 | Panasonic SV-MP020 MP3 Player
    RCA OPAL M4001 MP3 Player Logo
    19 people viewed this question
    Top RCA Audio Players & Recorders Experts
    Ekse
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
