DESPERATE CAN I MAKE A STARTUP DISK ON A CD INSTEAD OF A FLOOPY DISK
  • 88 Answers
You can make a startup CD instead of a floppy disk. First you have to open the BIOS and set the CD Rom drive as the First Boot seek drive.
Then follow the following steps in creating a bootable CD:
1. Create a bootable floppy disk that has all required driver and start-up software on it. You will need a CD driver in order to use the CD in a conventional manner once the system has finished booting. It is wise to use a generic CD driver if you plan on using it in a few different systems.
2 Make sure that any path names in the config.sys and autoexec. bat files do not specify drive letters.
3. Make sure your boot process does not attempt to write to the disk. Set the read-only flag on all files and write-protect the disk if possible. If your system tries to write to the CD on boot-up, it will crash.
4. Test this disk thoroughly in whatever PC environments you wish to use it.
5. Once you are happy with the bootable disk, create the CD with your CDR publishing package. Selecting the "bootable" option will usually prompt for the floppy disk. Put any other data onto the CD in the same session.
Posted on Mar 29, 2008
    Novelist:
  • 104 Answers
Yes you can but to help I need to know what operative system will you use to do it, which one you are going to bootup with... (better if its the same) and of course any info you can give...
SOURCE:
How do i remove a cd that is stuck in my car
Usually you can get them out using tweezers. One method I have found helpful is to get a floopy disk and remove the part that slides back and forth(this will make the floopy disk no longer able to store or read data) and use that like tweezers. I have removed a lot of CDs from macbooks using the floopy disk method.
Jul 03, 2012 | Toyota Sequoia Cars & Trucks
If I change boot set up in bios I cannot save it instead it freezes. I tried to reformat my hard disk after it got infected with trojans.
you have asus mb do this
remove hard disk ,cd/dvd rom and other devices as printer and floopy .
1- clear cmos methed for clear cmos (I) remove cmos cell. and plug it after 15 second. you will see menu for prees f1 key. (2) turn off computer , remove power cable (ac suplly) wait 15 second put a jumpher cap on cmos jumpher for 5 second.and remove.
after doing this plug the ac main power supply. turn on you computer go bios and save it as defalt by press f7.
Aug 18, 2011 | ASUS Computers & Internet
When booting up,it wants a floopy, instead of
try to change the boot sequence at bios. make sure that the first option for boot will be hard drive. hope this will help.
Apr 01, 2010 | E-Machines eMonster 500a PC Desktop
Boot up problem
I thiknk your hard drive may have failed/corrupt. If so, a simple reformat will do. But if it has crashed, you will have to get a new hard disk. If you are really desperate about your data on your dead hard disk, go for a hard disk recovery activity. It may be costly though.
Jun 05, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
Nov 10, 2008 | Dell Latitude L400 (220-3575) PC Notebook
I need Emergency Disk Floopy Content. If any body is having it please mail me.
If you need a emergency floppy disk go to http://www.bootdisk.com/. The emergency floppy disk only has boot files that enable you to possibly fix a windows issue.
Apr 27, 2008 | Compaq Presario 5000 PC Desktop
I have an old G3 and when I power it up it gives me a floopy disk in the middle of the screen with a ? mark flashing I have no start up floopy can you let me create one
You could try to start from the Disk Tools PPC (can be found here; the Disk Copy 6.3.3 utility, and another Mac with a floppy drive, would be required to make a bootable floppy from the disk image). Otherwise, an appropriate version of the operating system on CD will be needed.
Apr 10, 2008 | Computers & Internet
Floopy disk
Hi
Regarding configuring flopy drive for desktop please check these things
The wire on the ribbon cable with the red stripe is the pin 1 end and there should be a mark on the floppy drive as well marking the pin 1 end. Sometimes a little arrow or triangle point at pin1 sometimes stenciled with a number.
Regards
Balisonu79
Feb 14, 2008 | HP External floppy disk drive cable...
Open Questions:
aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...
Oct 17, 2019 | Computers & Internet
avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7
Oct 17, 2019 | AVG Computers & Internet
Computers & Internet Logo
85 people viewed this question
Ekse
Alun Cox
