Question about Dell Dimension 3000 PC Desktop
Need to replace cd-rom drive, how difficult?
Need to replace cd-rom drive how difficult? dell dimension 3000 pc desktop
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 121 Answers
CD-ROM drive can be taken out by opening the tower side cover. ther is a cord at the back of the drive which needs to be pulled out. then from the front side pull the drive out. also be careful to check it has some screws at the side or not. if not then it should come out easily.
Posted on May 13, 2010
What do I set my CD-Rom Jumpers to in a Dimension 1100
Which is it a Dell 3000 or Dell 1100 ?
The jumper settings on the rear of the DVD drive; set the jumpers to "cable select" mode (if you are uncertain how to set the jumpers, check the documentation that came with your drive or look for a diagram printed on the drive itself). Insert your DVD drive into the selected drive bay and connect the IDE and power cables. Use the screws that came packaged with the drive to secure the component to the drive bay.
Dell Dimension 3000 Service Manual
http://support.dell.com/support/edocs/systems/dim3000/en/SM/sm.EXE Dell Dimension 3000 Users Guide http://support.dell.com/support/edocs/systems/dim3000/en/OM/j6758A04.pdf
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
I have a dell dimension 3000. I wiped the computer, installed OS disc, but it says FAIL every time I try to do anything with the utilities & drivers disc. I also have no internet because it won't...
Right click on My Computer>Manage>Device Manager>does your CD-ROM have a yellow ? or ! on it?
If so, then you somehow need to install a driver for your computer to recognize your drive. If you can get an external CD-ROM that connects to a USB port, maybe you can install the drivers that way. Once that CD-ROM is working, then you can get the drivers installed for your modem. Hope that helps!
Aug 04, 2011 | Dell Dimension 3000 PC Desktop
I need to buy replacement internal cd-rom for my Dell Dimension 8110
Any IDE CD-ROM Drive will do just fine... Just make sure you configure the jumpers according to your specific setup (look at the old drives jumpers if you don't know).
Dec 05, 2010 | Dell Dimension 3100 PC Desktop
Need to replace cd-rom drive, how difficult? dell dimension 3000 pc desktop
It is not difficult to change cd/dvd drive.
Open cpu cabinet.
Then remove icd cable and power cable from cd/dvd drive.
Then remove screws of old cd/dvd drive.
Then you can pull it from cabinet from front side.
Then put your new cd/dvd drive into it's position then lock it with screws.
Then connect ide cable from motherboard and power cable to drive.
Then you can use it.
If you connect to drive with 1 ide cable means if you connect harddrive and cd/dvd drive with 1 cable then set harddrive as master and cd/dvd rom as slave you can set it slave with jumper settings.
It is in back side of cd/dvd drive.
There is instruction how to slave it with jumper.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 17, 2010 | Dell Dimension 3000 PC Desktop
I have a dell dimension 3000 desktop and the sound from the cd/dvd rom drive is distorted or choppy when i play a dvd rom or a cd
hi go to start, settings, control panel, click on sound and audio devices. on the volume tab locate properties and click on it. now another box will appear look for cd volume and adujst it whist playing a cd until the sound is less distorted. please rate me if this solves you problem.
Feb 23, 2010 | Dell Dimension 3000 PC Desktop
Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Dec 30, 2009 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000 CD/DVD drives not working
You can download the drivers from dell website, download.com, and many other sites. Download, then double click on them to install them. Once installed, reset pc.
Sep 13, 2009 | Dell Dimension 3000 PC Desktop
DVD drive help for Dell Dimension 3000
call DELL support and explain to them, they have send your the wrong type, what you have is IDE, they have send you the ATA. which the motherboard can connect.
Jan 09, 2009 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000 PC Desktop Logo
Alun Cox
