Question about Avaya MLS 12D Corded Phone
I have an avaya corded speakerphone without a user manual and I need to change the time on the screen to update it for daylight savings. How do I determine the model # etc.
Partner ACS, any release
Changing the time on a Partner system must be done from extension # 10 or 11. 1. At station(Ext.10 or 11) press feature, 0, 0
2. Press the left intercom 2 times
3. Enter # 103
4. Enter the correct time in 24 hr. format, for example:
* to set the time for 09:00 A.M., enter 0900
* to set the time for 04:45 P.M., enter 1645
5. Press feature, 0, 0
Posted on May 14, 2010
2 Suggested Answers
consultel1
  • 860 Answers
SOURCE: I have an avaya corded speakerphone without a user
The model number should be on a sticker on the bottom of the telephone set a "D' designation means that it has a display.
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
Posted on Mar 17, 2010
I have an avaya corded speakerphone without a user manual, and I need to change the time on the screen, to update it for daylight savings. How do I determine the model #, etc.
enter in "#103"
Mar 17, 2010 | Avaya MLS 12D Corded Phone
My clock went back one hour on Sunday 10/25, need to get it to move ahead one hour.
The clock program for Daylight savings Time is programmed for the old "third Sunday in October" changeover. The new changeover is the first Sunday in November. The program probably cannot be updated. If there is no button or setting to disable automatic change to Daylight Savings Time you can set the time manually and then change it manually to Daylight Savings on November 1 for the time to be correct.
Oct 26, 2009 | Emerson Smartset Clock Radio
Need to update daylight savings time date
This is from the Timex FAQs site:
Q: My clock did not update for DST.
A: We apologize but there is no patch available. Consumers must change clocks manually. Due to newly enacted government regulations, effective this year you must change the time manually, since the calendar was programmed to change according to the time DST issued by the government, it will not recognize the change after 2007. Now the time must be changed 4 times. Press & hold the time set button until the time flash, then release it and press the ff >> or << rev buttons.
Oct 26, 2009 | Timex T311T Clock Radio
Avaya 2410 speakerphone
hi
what you could do is duplicate the set-up of a working phone for the new phone and see if that works
to idle a phone use busy sta <extens> and release sta < ext>
May 22, 2009 | Avaya 4621SW
LG600G did not update time for daylight savings time
I had the same problem. I simply powered it off, and powered it back on, and it had updated.
Mar 10, 2009 | LG Shine KE970 Cellular Phone
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Reprogramming the date for daylights savings time.
From extension 10 or 11
feature 00
left intercom
left intercom
#126
press the 2 button
feature 00
That will disable it.
Apr 09, 2008 | Avaya Eurostyle 18D Corded Phone
Change the time
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Oct 29, 2007 | Panasonic KX-T7633 Corded Phone
Avaya MLS 12D Corded Phone Logo
94 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
