Maytag MMC5000 Microwave Oven Logo
A
Anonymous Posted on May 10, 2010
Hotpoint model# rvm1435wh001 working fine but not heating the food
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Mar 27, 2011
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10837566
Points
101584
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101[]][\-==-
Will not get food hot
The problem is most likely the magnetron "that heats food" and is breaking down. There are two other parts of concern, the high voltage diode, and capacitor that tie into the high voltage grid to work together. Depending on parts and labor will determine the final outcome of cost.
1helpful
Hotpoint Microwave oven Model RVM1435WD will not heat up. It will start and the fan runs, but will not heat any food,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
1helpful
Hotpoint overrange microwave, all the lights and timers work not heating food. there is also a smell when trying to heat is this a common problem with this microwave?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Microwave Oven Basic Troubleshooting Tips
heatman101
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
2answers
Brand new Hotpoint Microwave doesn't heat
Brought microwave back to store. It didn't appear to be something I would be capable of fixing myself.
Got a new one which is working fine.
Microwave power level
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If you don't have your owner's manual, you can download it free from GE/Hotpoint.
Please reply back if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
