Question about Norcent Technologies DC-420 Digital Camera
Battery Will Not Charge
I have a Norcent DC 420. Normally, when I plug my camera into the charger, the light will flash green to signify it's charging. Now, when I plug it in nothing happens. No flashing, nothing. I left it plugged in, and the battery just would not charge. Not sure whether this is a issue with the charger or the battery. Or, something internal?
One thing though, when I plug the charger in, it still emits a faint high pitched noise. But, I just want to be sure before I order a new battery. Also, anyone know a good place to do that?
  • Anonymous May 30, 2008
    Still can't find the battery!!!
  • 88 Answers
Hi amber_penn, battery charging problems usually come from two sources, the battery or the battery charger.
Check the contacts on both the battery and the charger for oxidation, dirt, etc. Try cleaning the contacts with a little alcohol on a swab. The charger seemed to still work judging from the humming sound. Next step would be to buy a new battery.
Try to follow this link http://www.livingroom.org.au/photolog/reviews/miscellaneous/norcent_dc420.php
Posted on Mar 29, 2008
SOURCE:
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Will not charge
Every rechargeable battery has a certain cycles of charging and discharging the battery. Not two batteries have the same life time. The amount of cycles a battery can have, can be influenced by the user. If you leave a battery without charging or discharging for months or even years, the lifetime can be shortened. That is why most of the time you get warranty on the equipment, but almost never on a battery. (sometimes a warranty of 90 days is given on a battery.)
Still when a battery won't charge, you could check all the parts in the chain. The AC / DC power convertor / charger the power cable.
When the light on the charger comes on, you can assume the charger is working.
If you can charge the battery in the camera everything looks the same. As soon as the green light comes on (starts to flash slow) you can assume the AC adopter is working. The charging of a fully discharged battery should take about 4 hours.
If the green light does not flash at all, check the adopter and check the USB cable. Be aware as long as the cable is in the camera, it can't be switched on. So before testing if the battery is charged, remove the USB cable.
Last but not least, if you have a multimeter, you could try to measure the voltage of the battery. It should be a little above the 3.7 volt that is printed on the battery. If not you can be sure the battery is no good at all.
Mar 09, 2014 | Nikon COOLPIX Cameras
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Laptop will not turn on and when you plug in the
You may have a DC Jack issue and needs to be replaced. Common with Acer models using the yellow DC jacks.
And since the battery will not charge, it is most likely a component issue. Shorted MOSFET in the charge section.
May 02, 2010 | Acer Aspire 5500 5570-2609 Laptop
Laptop won't charge
You might need a new battery....you could try removing the battery, plug laptop into ac and restarting. Or you might need a new DC power jack. If you wiggle the cord where it plugs into the laptop, and it starts to charge normally, then the DC power jack needs replacing. http://www.insidemylaptop.com/take-apart-sony-vaio-vgn-s360p-replace-broken-power-jack/
Apr 26, 2010 | Sony VAIO Notebook
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Camera will not charge the battery
Well. Ive got the same problem only ive gone thru 3 batteries trying to figure out what the problem is. When i plug it in to charge the light turns red , then within 5 sec's turns green. It stays green but never charges the battery. After 24 hours, its still a dead battery. Im just assuming since its 5 years old that the internal charger is shot. Looking for a new camera at this time.
Aug 20, 2006 | Gateway DC-T50 Digital Camera
Norcent Technologies DC-420 Digital Camera Logo
83 people viewed this question
Top Norcent Technologies Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Tony Parsons
Tony Parsons
Harrie
Are you a Norcent Technologies Camera Expert? Answer questions, earn points and help others
