Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have the RCA D52W20 ITC222.It was blinking
I have the rca D52W20 ITC222.It was blinking three times.replaced cp114120 and 150.Worked for about a week.now it flashes once real fast and thats it.any help would be great Thanks.
Rca d52w20 blinks 3 times, wont turn on
The set has a three strikes and you are out rule---tries to come on three times and then if fails, shuts down.
A short exists inside the set.
Mar 17, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV, was watching it one night just perfectly, then the next morning we turning it on and there is this 3-D effect with the three colors.. wtf.
Very common problem. You can get the repair kit called the ITC222 & ITC222A convergence option missing repair kit from www.tvrepairworld.com which contains the parts and the CD with instructions.
Jul 01, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 Light blinks 3 times, Replaced Flyback, Caps
I have the schematic, did the same thing and still have the problem. Any help?
Aug 12, 2009 | Televison & Video
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20
it should if you can get one most have been on back order. the board with the ihvt on it is the one to replace
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need part # on itc222 chassis
High voltage Capacitor ,Call Radio Shack see if they have any or Call Electronix 1-800-223-3205.
Dec 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52inch RCA model#D52W20 tv
the d52w20 rca chasis itc222 can be difficult to troubleshoot sometimes. there a few things you can assume at this stage. ONe it is NOT the fuse. The processor in this set is seeing a voltage or saftey shutdown issue. and is shuting the set down for saftey. THis is where the troubleshooting begins. High voltage or overcurrent conditions are generely the problem. \technicians have speceil computer diagnostic equipment that can read error codes in the processor. much like in a car. but without it yo0u pretty much have to check things like horizontal ouput transitor.
Mar 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Fixing a tv
57 inch rca....Sounds like you have a itc222 chasis but cant be sure... what is your model of the set. d52w20 maybe.. or something simular.. blinks green 3 times sound familar... get me that model number and we cant start the troubleshooting process
Mar 03, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
144 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
