Question about Mitsubishi WD-65833 65" HDTV
WD-65833 Flashing Green Light/Will not turn on!
When I press the System Reset button I get the rapid flashing green light; it never turns off and the TV never comes back. Heard about replacing the caps on the DM board, but where is the DM board? Any suggestions helpful...
  • 1 more comment
  • Silvaman Mar 29, 2008
    Have a service manual in hand! Thanks a bunch.
  • baseballgc Apr 25, 2008
    I am having the same problem as well. The TV is 110 lb paper weight.
  • Anonymous Jan 23, 2009
    Flashing green light, reset will not work. Unplug and plug back in, same thing green light flashes. I know the difference between a capacitor and resistor so can probably fix it if I have directions. Thanks for the help
  • Mitsubishi Master
  • 8,617 Answers
Its an easy repair however i would recomend not even attempting the repair without the service manual as the DLP chassis is completely incased and you will need the info just to get the chassis out , That will explain exactly how to disassemble. once disassembled there are 4 100uf capacitors that are causing the problem. If you would like the full service manual for your set let me know and I will post a link where you can get it emailed and they will provide free support to help you do the repair.
Posted on Mar 29, 2008
SOURCE:
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
protection circuit. Wait for the light to stop flashing and turn TV
on.
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
Tip
Chevrolet service light 1991-01
Camaro
1998-01
To reset the "OIL CHANGE" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and then goes out, the system is reset.
Corvette
1997-01
To reset the monitor after an oil change, turn the ignition on. Press the "TRIP" button so that the "OIL LIFE" percentage is displayed. Press "RESET" and hold it for two seconds. The word "RESET" should appear on the monitor, then "OIL LIFE 90%".
Impala,
Monte Carlo
2000-01
Turn the ignition to ON without starting the engine. Fully press and release the accelerator three times within five seconds. If the CHG OIL SOON lights two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHG OIL SOON light comes back on, the system has not been reset, repeat the procedure. Follow this procedure to reset the GM Oil Life System using the DE 100 Series Radio. Turn the ignition to ACC or ON and the radio off. Press and hold the DISP button on the radio for at least five seconds until SETTINGS is displayed. Press the SEEK up or down arrow to scroll through the main menu. Scroll until OIL LIFE appears on the display. Press the PREV or NEXT button to enter the submenu. RESET will be displayed. Press the DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second. Once the message has been reset, scroll until EXIT appears on the display. Press the DISP button to exit programming. A chime will be heard to exit programming. A chime will be heard to verify the exit.
Impala,
Caprice
1994
To reset the "CHANGE OIL" light, turn the ignition switch to the run position with the engine off. Access the reset button on the end of the instrument panel by the fuse block. Press the switch and hold it for at least 5 seconds.
Lumina,
Monte Carlo,
Impala,
Caprice
1996-00,
1996-99,
1995-96,
1995-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds. The light will flash and go out.
Corvette
1990-96
After an oil change, or when "CHANGE OIL" appears on the Trip Monitor, with the ignition on and engine off, press the "ENG MET" button (located on trip monitor) once. Press the "ENG MET" button again within 5 seconds. Within 5 seconds, press and hold the "RANGE" button (1990-1994) or "GAUGES" button (1995). The light will flash. When it stops flashing and goes out, the system is reset.
Chevrolet Suburban,
GMC Yukon XL,
Chevrolet Silverado,
GMC Trucks Sierra
2000-01,
1999-00
Turn the ignition key to the RUN position. Fully push and release the accelerator pedal 3 times within 5 seconds. If the CHANGE OIL SOON light flashes 2 times, the system is reset. However, if the light comes on and stays on for 5 seconds, the system did not reset. Repeat the procedure if the system does not reset.
Silverado, Sierra Trucks
1991-93
To reset the "CHANGE ENGINE OIL" message, turn the ignition key to the run position. Press and release the accelerator pedal three times within 5 seconds. If the light flashes for 5 seconds, the system is reset. Repeat procedure as needed.
on Dec 07, 2009 | Chevrolet Camaro Cars & Trucks
Timer is on and Tv will not come on
Press the System Reset Button which is on the RHS on control panel
If the TV fails to respond to the remote control, control panel
buttons, or will not power on/off, press the SYSTEM RESET button on the control panel.
The green LED on the front panel will flash quickly for up to one and a half minutes. When the green LED stops flashing, you may turn on the TV. Recent setting changes you made before using SYSTEM RESET may be lost.
If that fails try pressing and holding the menu button for 8 secs
user manual is here:
http://content.abt.com/documents/19051/WD_C-735-736-835-series_om.pdf
Apr 03, 2014 | Mitsubishi WD-60735 Projection Television
Is not working more
Switch the printer off.
Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
Open and close the lid of HP printer once. The light will start blinking.
Press the green button. Your HP toner cartridge chip will be reset.
Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
Mitsubishi WD-65833: Reset system on my WD65833 after replacing the DMD chip. Now get a flashing code of 1-2. Any suggestions?
You are not the first person I have seen who replaced the display chip and had fubar after--1,2 is no error found.
You might want to do a little more research: Mitsubishi when changing the optical engine has a procedure so the engine can communicate with the digital circuit in the set--opps!
By the way the reset on the front is only a boot up for the set--set also has a hidden option menu for a hard reset of the entire set to factory defaults.
tried that one?
Mar 31, 2012 | Mitsubishi WD-65833 65" HDTV
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
Wd73737 blinking green power light
my tv keeps turning off i have a mitsubishi wd-73737 what can i do to fix it?
Jul 12, 2010 | Mitsubishi WD-73737 73 in. HD-Ready TV
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-65833 65" HDTV Logo
796 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
