Make noise when copying - Office Equipment & Supplies
  • robertsand May 14, 2010
    this could be caused by many things, please provide make and model, this will help you get a response
  • 59 Answers
Dear u dont have mention the model and make witch some grinding noise or some other kide of noise if grinding there is any gear problem or if any other kine of noise may be any bushing dryed, other noise for the bearings in the heater unit i hope tis will help you
thanks
Posted on May 15, 2010
NOISES DURING COPYING
open rear cover and check the fuser to see if there is wear on the heat roller, if there is a line worn in the roller and it makes a grinding noise,
it will need the fuser replaced, also it may need a firmware update.
Apr 02, 2014 | Copystar Kyocera Fs-1135 Mfp Multifunction...
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
Display panel not powering
Is there any noise when you switching on the machine similar to its ready mode noise,
Check machine by pressing Copy button to make copies if it copying and working means your display only faulty or...
If it is not copying or not working means it has problem in Main board check RAM and Boot Flash Rom
Check Boot Rom correctly may be boot ROM faulty
Feb 08, 2013 | Canon imageRUNNER C3200 Color Printer
Copier keep making noise while copying
Do you see any issue with the print quality? If everything is working ok and it's still making a noise call your photocopier provider.
If you dont have one, i work for a xerox partner. Either call or email us and i will get someone to advise you.
Mar 19, 2012 | Xerox CopyCentre C20 Black and White...
OUR XEROX COPY MACHINE MAKES A SQUEALING NOISE WHEN MAKING COPIES
On this model most squeeling noises come from the fuser assembly.
If it is that loud replace the fuser assembly.
Other known prolbems is with the fuser fan in the back.
To see if it is the fuser fan, take off the back cover.
When the machine makes a copy unplug the fan very momentary. See if the noise goes away.
If the noise is still there, then it is possible the fuser is causing the problem.
Make sure the correct fuser is installled on this machine model.
Oct 21, 2009 | Xerox CopyCentre C20 Black and White...
Dvd writer makes noise when copying movies
if the movies are copying ok then it will just be a noisy burner, possibly some vibration also, mine is the same, noisy but burns ok. You can try and reduce some of the noise by taking the side panels off and make sure the screws are tight on the writer
regards
Nov 20, 2008 | Computers & Internet
Ricoh Aficio 1018 - Squeaky noise when it copies.
It could need a fan replacement. Possibly the bearing is going out on it causing the squealing noise
Sep 15, 2008 | Ricoh Aficio 1018D Copier
HOW CAN I STOP THE COPIES FROM SHIFTING EVERYTIME?
Wide blank area on Lead Edge, or Misregistration possibly accompanied by noise. The noise may be described as a clicking, buzzing noise while making copies. The noise may stop for short periods while making copies. Cause:
The registration Sol. pawl is not capturing the clutch to keep it from turning. This is caused by the Registration Sol. return spring being out of position, or when installing the Main Drive Assy., the pawl is "trapped" in the actuated position.
Apr 16, 2008 | Xerox WorkCentre XD120F Laser Printer
Upper feeder tray copies work fine, main feeder does not print, makes odd noise
Found the answer.
Problem:
The registration Sol. pawl is not capturing the clutch to keep it from turning. This is caused by the Registration Sol. return spring being out of position, or when installing the Main Drive Assy., the pawl is "trapped" in the actuated position. Solution: Free the Spring, by rotating it. Ensure that the Pawl moves freely in and out, and engages with the clutch.
Apr 02, 2008 | Sharp AL 1631 Copier
722 people viewed this question
jasbo
jasbo
