Sir I am having intex 2.1 sound blaster model it -3000 spaeker as its one speaker tuiter is bent slightly so is ther A need to repair it.. Or not .as ther os no problem now ...
cancerags
  • 36 Answers
SOURCE: Connect BX8A speaker to PC
Hello waddragon,
First, let's start with the BX8a. Those are powered speakers (built-in amplifier in each) so, you do not need a pre-amp. What you need to connect them to your computer is a 3.5mm to XLR cable OR a 3.5mm to 1/4" TRS cable, also known as 3.5mm to two 1/4" mono plugs (the back of the BX8a has inputs that accept either type). Cables are available at most any electronics stores. Make sure you buy a long enough cable to run from the back of the computer to where the speakers will be.
It sounds that you only have one BX8a which means you'll be listening to only one channel of the stereo output. In any case, make sure before connecting the speaker(s) to the computer that speaker power is off and volume control is at minimum. Connect the 3.5mm cable end to Line Out 1 jack of the X-Fi sound card and either the XLT or TRS ends to the speaker(s) input(s). Play some audio content on your computer, turn on speaker(s) and slowly increase volume to a safe level. Everything should work fine.
Let me know how it goes.
cancerags
Posted on Dec 28, 2007
sanjin
  • 56 Answers
SOURCE: Speakers sound quiet and unclear
You probably burned tweeters and damage midranges but before disasembly check equalizer
Posted on Feb 29, 2008
SOURCE: Hook up pair Bx8a to pc
XLR? not true. gold plated, balanced trs cables have a better sound and actually compliments the bx8's technology. that said, you can get cable that is trs-balanced on one end and rca's on the other. then just get a "Y" right-left rca into a stereo 1.5 cable. easy and cheap. but using xlr's for output? NO. save those for your input MIDI instruments and controllers.
Posted on Mar 07, 2008
  • 9 Answers
SOURCE: sound problem
I have a creative SoundBlaster LIVE! 24 Bit External Sound Card and this annoyed me for weeks.
depending on your surround sound reciever depends on the solution.
i have an Acoustic Solutions surround sound system with coxial and optical inputs, aswell as stereo red & white jack inputs.
not knowing the method or connection your using makes it difficult to give you a single solution so i'll list a few.
The soundblaster software shoudl include the Creative Audio console with all sorts of effects, one is CMSS (CMSS-3D) Stereo widening which is still stereo but gives a surround sound effect.. but i'm guessing you payed for 5.1 and you want 5.1 onto the next part
5.1 surround sound can only be produced when the actuall audio your playing contains 5 channels of audio, for example you cant play a stereo song in 5.1 surround sound without some sort of hardware or software sound manipulation. Luckily my surround sound system has Pro Logic II built in and some other effects which convert a 2.1 signal to a 5.1 signal and it works brilliantly. I'm not sure of a software alternative.
setup for your soundcard will be different under XP and Vista also, but there should be a properties option for your sound device where you can select your speaker setup such as headphones, built in speakers, 2.1 speakers, 5.1 speakers, 7.1 speakers and you should be able to manage this from the creative software.
If using Coxial / Optical or SPDIF under vista you MUST set the playback device as SPDIF, at least you have to with my sound card and drivers and seems to be a limitation of the actual sound card drivers for vista.
Personally i was looking forward to hearing the windows login melody in 5.1 surround sound too, but this doesnt happen.
Infact i find that almost all programs bar a few will not play Dolby Digital or DTS 5.1 surround sound via any or my output options hence the next solution..
if you have the 5.1 sound but winamp simply just plays it in stereo try the following.
You need to use DirectSound Output:
Preferences (Ctrl-P) > Plug-ins > Output > Select "DirectSound Output"
That should work in most cases, but if not, then:
Checkmark: "Allow hardware acceleration" in DirectSound Output config,
and make sure your sound card/chip is selected as Output Device.
Note that any changes will take effect only after playback is restarted.
In some cases, a Winamp restart is required.
If that doesn't work make sure you have the latest version of DirectX
(v8.x or higher is required)
Winamp 5.25/5.3 and higher:
For actual multi-channel files (ie. aac/wav/ac3/ogg/wma files encoded in 5.1ch surround, as opposed to standard 2-channel stereo mp3's), you need to checkmark "Allow surround sound" in 'Winamp > Prefs > Playback' for the music to play in its original 5.1 channel format (Note that this setting is checkmarked by default).
Windows Vista:
In addition to the above instructions, Vista users will also need to go to:
Control Panel > Sound > Playback tab > Speakers > Configure:
Select: 5.1/7.1 Surround.
Then:
Control Panel > Sound > Playback tab > Speakers > Properties > Enhancements tab
and checkmark "Speaker Fill"
Hope this helps
Anthony Kinson
Posted on Apr 22, 2008
SOURCE: intex sound card driver for win vista bit 32
sir, i m unable to install intex sound card on vista
i have driver which works on win xp.
plez sir give me the link from where i can download driver for win vista
Posted on Sep 28, 2008
Circuit diagram 5.1 intex
MY INTEX 2.1 SPEAKERS BOTH SPEAKERS ARE WORKING OK, PROBLEM IS IN WOOFER, AND THE SYSTEM IS CONNECTED WITH pc
wHAT COULD BE THE POSSIBLE PROBLEM???
Aug 18, 2012 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Need a MS0490B sound module
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10005159.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-sound-blaster-audigy/3000-2120_4-10198811.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html http://download.cnet.com/sound-blaster-pci128-drivers/3000-2120_4-10038063.html
hope one of these will help you
Oct 31, 2011 | Creative Labs Gigaworks S750 Computer...
I want sb0220 sound driver
http://download.cnet.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
This is the latest driver update for the Sound Blaster Live! series of audio cards only for users running Windows 95 and 98. This release includes updated version of Surround Mixer 1.0 and AudioHQ, 1024-voice software MIDI synth for Sound Blaster Live! (Option to select up to 1024 software voices), and improved support for Occlusion and Obstruction effects in EAX2.0
http://download.cnet.com/creative-labs-sound-blaster/3000-2120_4-10005159.html
If you're using Windows 95/98, you can download this file and update your Sound Blaster 16, Sound Blaster 32, and Sound Blaster AWE drivers. Please refer to the readme file for installation instructions. This new version solves the audio distortion problem that occurred when the Sound Blaster 16Xpress chip was left running overnight.
http://download.cnet.com/sound-blaster-pci128-drivers/3000-2120_4-10038063.html This is an updated driver release for Creative Sound Blaster PCI128 for Windows NT only
http://download.cnet.com/sound-blaster-audigy-driverpack/3000-2120_4-10198813.html The driver contains optimized support for Windows 2000/XP operating systems and is designed for use with all current models of Sound Blaster Audigy audio cards (all existing Sound Blaster Audigy Card to SB023x models). Features includes: drivers are WHQL Certified; provides Dolby Digital decoding from external SPDIF Input; speaker settings in Creative Audio Mixer are synchronized with Windows Multimedia setting; new presets and effects added.
http://download.cnet.com/creative-sound-blaster-audigy/3000-2120_4-10198811.htmln This update is for all Audigy 2 and Audigy 2 ZS series audio cards, which include the Platinum, Platinum eX, Platinum Pro, Digital Audio and Gamer versions. This update is not meant for original Audigy series audio cards. This update contains additional features and fixes to improve the performance of your Creative Sound Blaster Audigy 2 or Audigy 2 ZS series audio card.
on cnet download.com you can find these drivers hope one of these will help
Jun 12, 2011 | Creative Labs Creative Sound Blaster Live...
Driver for vista Creative Sound Blaster Model : SB0680
You can find the drivers here:
http://xpdrivers.com/sound-audio/creative/_3_2359.cfm
Jan 22, 2010 | Creative Labs Sound Blaster Live! 5.1...
Lost Sound card installation cd
Dear sir, i have lost my creative installation cd. i have have purchased a sound card model no SB0680. Can you help me to get back the sound
Jul 29, 2008 | Creative Labs Sound Blaster Live! 5.1...
207 people viewed this question
 Grubhead
Grubhead
