Question about Jenn-Air JER8850 Electric Kitchen Range
F1 code on display pad
When cooking, the electronic display started flashing, then went blank, then code F1 appeared and a beeping noise started. I reset the panel and the beeping stopped, the code disappeared, and the normal display of time and oven temperature came back on. The range burners work normally and the oven turns on, but I can not set the temperature other than the preset temp. of 350. The numbers on the touch pad no longer work.
  • Anonymous Jun 03, 2008
    My problem is a little different. The timer goes off at times when stove
    is not being used, like in the middle of the night. F1 is displayed. Sometime it will not stop by using the clear button. I have to cut off
    at breaker box.
  • Anonymous Mar 20, 2014
    Constant water noise. Display shows an ERR 1 code. I reset it according to the manual.
    The display also shows Regen and it is flashing.
  • 83 Answers
You have a bad touch pad.
Posted on Mar 29, 2008
Error Code F1 displays once in a while. What does it mean?
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
1. Disconnect power to stove
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
7. If you get the F1 and beep, replace the ERC.
8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
* ERC - Electronic Range Control
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
Apr 20, 2011 | Ovens
My stove is flashing this code "-F1-" on the display, some of the buttons work and some do not. All of the problems started at the same time. Also, the front right side by the knobs seem...
Hello & Welcome to FixYa
Error code F1 indicates electronic control failure and is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Amana ACS7270AS Electric Kitchen Range
What could be the problem if F1 code and beeping in GE wall oven/
F1=Touch control pad and or Clock defective.
Jan 11, 2011 | Ovens
Displaying F1 error
Apr 04, 2010 | GE JGRP17 Gas Single Oven
I have a tappan range that keeps getting F1/F3 in on the display panel.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Mar 03, 2010 | Tappan TGF363 Gas Kitchen Range
It displays F1 . Is this a fuse problem and where is the F1 fuse
HELLO THERE
Feb 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
F1 error code and beeping on a ge doubleoven
Hello there:
Jan 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a maytag oven with f1 and f3 codes what
F3: Open or shorted sensor. The cancel key resets the control and stops the alarm. If fault is still present it will reactivate the alarm when the cook mode is chosen. Correction: Check sensor and wiring for shorted or open circuit.
Nov 09, 2009 | Kitchen Ranges
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Jenn-Air JER8850 Electric Kitchen Range Logo
404 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
