Question about Sub-Zero 650/SRH Stainless Steel
I need to replace the light bulb in my Sub Zero 550
SOURCE: Sub-zero 550 series
I had this problem in the fridge portion last year and replaced the switch at the top of the door. Problem solved. There should be two switches: one for the lights and one to turn off the compressor when the door is open. I don't remember which one was which. Try the link below for the part, but double check to make sure it's the right one. They have an 800 number to call as well. Good luck
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=753971&PPStack=1
Posted on Jul 22, 2008
  • 56 Answers
SOURCE: Need to change the light bulbs
The light shield has two tabs, one on each side. They may be on the front or back of the shield, It fits either way. Pull the tabs down and slide the shield back and forth a couple of time and it should drop from the four pegs that hold it in place. You will have access to the bulbs. You can go to http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 and find a parts distributor near you or take a bulb to the store and match it. Make sure you get the same wattage rating.
Posted on Dec 03, 2008
  • 56 Answers
SOURCE: installing cams to sub zero 550
http://www.subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code is the locator area parts distributors. Once you get the parts in, remove everything from the door, food, shelves.... Then with the door closed remove the upper hinge. If you have a left hinge unit you can bend the shroud out of the way and bend it back when you are done. The door can be quite heavy if you have wood panels on it so you may need help. Open the door 90 degrees and lift up and over the bottom hinge. Remove the cam from the door using a phillips head screw. Then replace the hinge cam that is on the hinge that is still attached to the body. Now you will need help, lift the door up and have some one set it into the lower hinge pin. Close the door and have some one hold it closed while you climb up and reinstall the hinge. You may have to adjust the door by sliding it forward and back left and right until you get your sight line just right.
Posted on Dec 16, 2008
  • 71 Answers
SOURCE: sub zero 550 refrigerator light not working
first try to tightin the bulb, it has a seal and it's hard to drive it home. otherwise it could be the door switch.
Posted on Dec 24, 2008
SOURCE: Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
Sub zero 690 side by side
Behind the panel and the control unit are light bulbs, They made need to be replaces. Good Luck
Jul 30, 2014 | Sub-Zero Refrigerators
I need instructions how to replace the cold control on Sub-Zero 550 Freezer.
Here is a pic of the insides. The cold control is at top right of this pic and the capillary tube goes from it across to middle and then down the centre. All this is can be reached from the back of the refridgerator.
http://www.bing.com/images/search?q=Sub-Zero+Model+550+Manual&Form=IQFRDR#view=detail&id=E7AB2341111D09E747ABB1092D17C1338277BB7F&selectedIndex=0
Dec 20, 2013 | Sub-Zero Refrigerators
I HAVE A SUB ZERO 550 . THE LIGHT SWITCH ABOVE THE DOOR ISN'T WORKING. TO TURN ON THE LIGHT I NEED TO JIGGLE THE PLUNGER SWITCH. DO I NEED A NEW SWITCH?
Probally do need a new switch, you and try spraying like wd 40 arould the plunger and working in in and out. Hope this helps. Wally
Oct 09, 2011 | Sub-Zero Bottom Freezer Refrigerator
What does the second switch about the door in the refrig control. we know one is for the light what is the other? we have a 550 sub zero
Typically the second switch is for the ice dispenser and fan,when the door is open the fan and the ice dispenser power is cut off via that second switch
GENE
Sep 24, 2011 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 550 with burnt out light bulbs in freezer, can not figure out how to remove them and replace.
Open the freezer drawer, the light bulbs are not covered, just hidden. If your able, get on you hands and knees, with the drawer open, look inside and up, the bulbs are in front on the top of the freezer compartment and can be unscrewed to replace. The above comment meant is you have issue to preform the task of being on your hands and knees, then laying down could help. As I get older it becomes more difficult to even change a light bulb somedays.
Good luck
Jul 23, 2011 | Refrigerators
We replaced all of the light bulbs in our 550 and the lights still do not work, any ideas?
Most likely light switch is bad. Could be light limit t-stat (prevents from overheating) and wiring problem too.
Feb 06, 2010 | Sub-Zero Refrigerators
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub zero 550 refrigerator light not working
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 550 series
Jul 21, 2008 | Sub-Zero Refrigerators
Sub-Zero 650/SRH Stainless Steel Logo
511 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
