Question about Philips VR750 VHS VCR
I have a video cassette stuck in a philips vr 700. The screws are not normal. How do I open the vcr?
  • Philips Master
  • 5,190 Answers
You will need a special screwdriver. Depending where you live try searching in electrical parts shops such as Maplin (UK) or Radio Shack (USA). They might be what are called tamper proof screws or something along those lines. You could also try google image search to see if you can try to find the type of screw. Try entering "Tamper Proof screws" first and see if any resemble yours.
Posted on May 14, 2010
I use a Service Manual for VCR Pilips VR 256
HI.....................
HERE IS THE DOWNLOADED LINK OF
Service Manual OF
VCR Philips VR 256
  • http://www.nodevice.com/user_manual/philips/vcr/vr256.html
  • http://www.usersmanualguide.com/philips/home_audio-video__vcr/vr256
GOOD LUCK....................
N ENJOY.............
Sep 23, 2011 | Computers & Internet
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Will not eject cassett
try this unplug and then keep finger on eject and plug back in keeping hold of eject if not work then
UNPLUG and take top off video and you will see were the tape is stuck THERE WILL BE A RUBBER BELT ON ONE SIDE OF MECHANISM TURN COGS THAT BELT ARE ON ( USELY ANT-CLOCK ) takes time you will see parts move towards front of video ( IF NOT CHANGE THE DIRECTION TURNING ) the tape will come out when finished
THEN PLUG IN SO VIDEO CAN RESET MECHANISM
Nov 08, 2009 | Cell Phones
I Need a Manual for a philips VR 550 Video wilson@theyealm .co.uk
You have not mentioned which version of VR 550 user manual you need but the following pages at nodevice.com give you free dowloads for your manual: you will need to copy and paste these links into your URL window in internet explorer.
http://www.nodevice.com/user_manual/philips/vcr/vr55002/download.html
http://www.nodevice.com/user_manual/philips/vcr/vr55007/download.html
http://www.nodevice.com/user_manual/philips/vcr/vr55016/download.html
You have to enter the verification code at the bottom of the page correctly before you can access your manual
Oct 05, 2009 | Televison & Video
VHS stuck in Philips VR 175 VCR (pal version)
the most common method is to unplug from the wall,plug it back with your finger on the eject button. if this does not work, then will have to take the top off and tenderly back the wheels or off until it gives you the tape back
Sep 09, 2009 | Philips VRZ250 VCR
How to open an old cassette that doesn't have any screws?
Some bargain tapes were made with glued-together shells. They were usually sold in bulk packaging in the days of cassettes for voice recording (for students taping lectures, for instance) but weren't meant to last long. You need to break open the shell and transfer the tape into another one after you repair the problem. Use a stiff blade along the seam to open it. I use a shop knife to get the cut started, then wedge a stiff putty knife into the opening and twist. The shell splits open pretty easily once you start it.
Mar 10, 2009 | Philips Audio Players & Recorders
Door jammed open, no power
oN THIS VCR THERE IS 8SCREWS TO REMOVE THE COVER, REMOVE THE COVER CAREFULLY THEN PLUG THE CORD INTO THE WALL, THE CARRIAGE TRAY WILL ACCEPT OR REJECT THE CASSETTE. oNCE THIS PROCESS IS DONE AN THE CASSETTE IS REMOVED UNPLUG THE VCR AND REPLACE THE COVER WITH THE SCREWS
Jan 13, 2009 | Panasonic PV-V4540 VHS VCR
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
Error 2 on Front Panel
I'm not sure if this is a solution, but it cleared up the problem for me. It turned out there was a loose paper label for the cassette that got stuck inside the VCR with the cassette.
I had to take off the top of the VCR by removing the three screws. I then removed the jammed loose paper and then was able to get the cassette out. The flashing number 2 (whatever that means) went away. The machine seems to be working fine now.
Apr 19, 2008 | Philips VR620CAT VCR
Cassette stuck in video
I am a sanyo VCR technician and i will share to you what i had encountered. the problem of your VCR is in the mechanism "slide front" unable to push out the ejector portion of the tape. If you can locate this part just push it so that the tape will eject.
Aug 28, 2006 | Philips VR630 VHS VCR
Philips VR750 VHS VCR Logo
190 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
