Question about Libec TH-M20 Tripod
I have one aluminium tripod Viola and I need to fix it
I have one aluminium tripod Viola and I need to replace two clamps.
Could you please tell me If I can get that kind of spares to fix it.
Thanks a lot for your answer.
Best regards,
Gustavo
email: gustavo.guidi@personal.com.ar
Tip
Thank you very much. My Elite took five cycles of the button sequence to enter...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Sep 18, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
I Need a replacement clamp/holder for one of the tripod legs for my Tasco telescope. The tripod legs are 5/8" dia & each leg fits into its own holder. one of the leg holders are broken and needs t
Looking at your other posts, you don't seem to have a lot of luck with technology - perhaps change the focus of your interests, hmm ? For your scope / tripod problem, take it to a service centre.
Nov 16, 2017 | Optics
The leg clamp on my tripod is broken i need to find a replacement
They were not made to be serviced. They were made to be disposable essentially, but you might contact the folks at B&H to see if they may have a solution.
Otherwise depending how it broke, it might be able to be cemented, or reconfigured to accept a different type of clamp. I had a no name type of tripod that required some caredul filing to restore a lip on a clamp so it would lock after the original lip snapped off.
Jul 07, 2012 | Dynex 60" Universal Tripod
Hello, For months now I cannot find the part that screws onto the bottom of the camera, which is then clamped to the plate...where can I get such a piece?
Take tripod to nearest camera store and tell them you need a quick release. Take tripod so you can try different shoes.
Dec 27, 2010 | Dynex 60" Universal Tripod
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
I have a Vivitar 50x/100x telescope. One of the
No replacement parts available for that telescope. Suggest you take the tripod to a well stocked hard ware store and see if they have any screws, bolts, or clamps that would repair the tripod.
You can buy another photo tripod of course.
Oct 23, 2009 | Vivitar Optics
Leg slips will not lock
Although I'm not familiar with your particular make and model it sounds like a common problem which affects many other tripods. If the legs clamp with a lever action then if you closely examine each clamp as you activate the lever I expect that you'll find a small crack opens up in the clamp assembly.
It's a faulty design as the clamps simply aren't strong enough for the load and eventually crack due to fatigue. Some manufacturers supply replacement leg clamps but they also fail and fitting them usually costs more than the tripod is worth.
Next time, consider buying a tripod which has rotating collars to lock the legs with. They're not as quick to operate as lever action (a.k.a. "quick release") clamps, but they don't take much longer and last far longer. Rotating collar clamps are only suitable for tubular legs, and to be as rigid as extruded profile legs there's usually an increased weight penalty unless you spend far more on carbon fibre versions.
Personally, I tend to buy cheap but perfectly good non brand name lightweight tripods which I can get for £10 including a carry bag and handle and expect to have to replace them when broken: usually about once a year. It's a lot cheaper than spending over £300 on a good one and means I can afford to have a spare one in the car.
ALDI (in the UK and Europe) sell a £10 tripod which comes with a handle, carry bag, pan/tilt head,quick release leg clamps, geared centre column plus two quick release mounting plates and has a bag hook at the bottom of the centre column; it even has a no quibble three year guarantee. It's not a smooth or as well built as many, but can't be beaten at the price.
Aug 06, 2009 | Vinten 3770-3 Tripod
I need a replacement tripod socket for minolta stsi
Hi there and welcome to FixYa.
Depending of your use of the tripod, (meaning, if your a professional photographer, or just a hobbiest = how much money your willing to invest to fix it!) there are a couple things you can do.
Purchase a clamp on head for your tripod. There are many on the web to choose from.
Or: (if you want to truly McGuyver it)
Take off the the screw so the tripod head is flat then use double stick velcro tape. Put one half on the bottom of your camera and the other on the flat part of the tripod. That will do the job for the hobbiest with for very littel money.
Hope this helps.
Rob
Mar 24, 2009 | Minolta Maxxum STsi QD 35mm SLR Camera
Libec TH-M20 Tripod Logo
229 people viewed this question
Top Libec Photography Experts
Tony
Are you a Libec Photography Expert? Answer questions, earn points and help others
