Question about Sony Playstation 3 (PS3) Console
I was in the middle of a game and it switched off on me. Now it beeps , the red and then blue light comes on then it switches off again
    Scholar:
  • 57 Answers
If it continues to bilnk a red light after it turns off, this is known as the yellow light of death(ironic i know). This is caused when the unit overheats causing solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
If the unit is not under warranty go to www.wiredextreme.com. We are a console repair company based in Texas, and we can get your console up and running again. All of our repairs come with a 90 day warranty that covers the whole console, not just what we repaired. We also offer extended warranties up to 4 years at additional cost. If you have any other questions/concerns feel free to email support@wiredextreme.com or call toll free 1-888-389-3038.
Posted on May 12, 2010
Strech it is a dash mounted I have five gallon fat bobs key switch in middle
The BLACK wire (that you say you know goes to the battery), would be the HOT lead, shown as a TAN wire in the diagram.
Per the diagram, it actually connects to lug #1 on the STARTER RELAY.
As far as the RED and BLUE wires, you need to figure which is for the lights, and which is for the ignition.
My GUESS is RED's the ignition, and BLUE is the lights.
If your switch is a THREE position (ACC, OFF, IGN), it might not matter, as these switches are set up to run the lights whenever the ignition is on.
The older FOUR position switches (ACC, OFF, IGN, LIGHTS) are so you can manually select if you want to run the headlight or not, and would also have a fourth wire coming off the switch.
Feb 10, 2014 | Cars & Trucks
Brought a second hand ps3 slim 160gb.when everything is on tv says no signal i hold button down but no beeps light goes from green to red anybody help please
Try this Make sure no game in ps3 turn ps3 off and by the switch at the back unplug it wait a couple of sec then plug it back in turn on buy the switch at the back then hold down power and eject hear a beep keep both preseec till 2nd beep let go should be able set it to ya tv
Dec 28, 2013 | Sony Playstation 3 (PS3) Console
In the middle of a game online it went black and now the game disc will not eject. Also when we turn it off and on again , when we press the front right to turn it on the console light goes green for 1...
HARD RESET
1. Power Off the PS3 via the power switch in back and power back on w/switch. (60gb FAT if no switch in the back unplug it then plug it back in after a few seconds)
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Oct 17, 2010 | Sony Playstation 3 (PS3) Console
When i switch my ps3 on it comes up on the tv CANNOT START. THE CORRECT HARD DRIVE WAS NOT FOUND can you help me
Hi if you replaced your hdd or if the old went foul try this plug your controller in with the usb lead insert a game disk put it on standby (red Light) press and hold the power pad you will hear beep,beep, then it will shut down, Do it again beep, beep then beep beep take your finger off then follow your instincts on what it says good luck
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
In the middle of playing it shuts off and a red light starts to beep and flicker on and off
Unfortunately, you are going to need to have your PS3 serviced by Sony. If your disc is stuck inside, if flip the switch button off on the back of the PS3. Then press and hold the eject button and turn the button at the back on again. This should eject the disc.
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
My playstation3 just cut off in middle of game, red
Thats the red light of death.
Visit this website if you want information on how to fix it.
Feb 26, 2010 | Sony Playstation 3 (PS3) Console
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
Think my ps3 is done!!!
off hand...Id say HD gone south.....
Jun 24, 2009 | Sony PlayStation® 3 (80GB) Console
Wiring a double light switch
Electricity can kill!
Proceed with caution some of the wires (probably the red) may be live all the time. IF IN DOUBT CALL AN ELECTRICIAN!
First thing is to remove the fuse from or switch off the circuit breaker controlling this circuit and ensure all wires are dead using a circuit or neon tester.
Check the back of the switch terminals should be marked C (for Common), 1 and 2 for each switch. The red wire that was fixed would most likely have been in a C terminal, the other red wire that was free should go to the other C terminal.
The fixed blue wire may be in a 2 (or sometimes a 1) terminal, fix the other blue into the same numbered terminal of the other circuit.
Mar 28, 2017 | Kitchen Appliances - Others
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
