Question about Dell Dimension 4600 PC Desktop
Connecting front panel leads of generic case to 4600 motherboard
I have a spare Dell Dimension 4600 motherboard (F4491, same as 2Y832 and Optiplex 170L motherboards) that I am installing into a generic case.
My problem is matching up the front panel leads to the motherboard connector. The case front panel leads are: a 2-wire power LED, 2-wire power switch, 2-wire reset switch, and a 2-wire speaker lead. The motherboard has a 9-pin front panel connector (J9G1) and a 9-pin control panel connector (J7J2).
Separate question: what is a TAD connector (a 4-pin on the motherboard)?
What happens if I try the trial-and-error method?
Thanks.
Jerry
  • Anonymous Mar 19, 2014
    i have only 9 pin connector
-MrSlickShoes
Posted on Mar 20, 2009
  • Anonymous Mar 20, 2009
    (this is the pinout for the J7J2 connector)
  • Will Back
    Will Back Jan 09, 2014
    thank you so much i was just triying to find how to start the bord and this worked perfectly
The 10 pin (one pin missing as a key pin) front panel connector on the Dell 4600 had the following pin out:
this end pin
function is
unknown
BUT must
be gnded
to center
pin
l
l
l ground
l ______ l
l l
l RESET
l l l HD LED
l l l l l +
o o o o o
x o o o o
l l l l +
Power l l
Switch l l
Power
LED
Posted on Sep 20, 2009
  • jwjenkins36 Dec 18, 2010
    hi all thanks for the useful info the best i found yet after days of searching but just one question which pin would be considered the center pin to ground the NC pin?
I have just pluged my front panel to clean my pc but i have just forget to join it . please help me
Posted on Sep 20, 2008
    Novelist:
  • 104 Answers
All motherboars come with the pins structure detailed or labeled... should be easy for you to find them... if they have no particular labels for pwrled, reset, pwswitch... but you are sure of which is the front panel connector group of pins.. you can try... no harm will be done to the motherboard... (in fact you can make contact between pins with a screwdriver, of course avoiding touching other parts... and you will find basically which 2 pins are for power and which other 2 are for reset... just by delicate touches between 2 pins...) of course do it gently and touch nothing but those front panel pins with the motherboard connected to ATX power supply. Otherwise just front panel wires till you get it.
TAD applied to that hardware usually means "technical audio devices" and its meant to connect special speakers or audio devices... such as digital outputs and those sort of stuff..
Posted on Mar 29, 2008
  • 111 Answers
Let take the last first the trial-and-error method will fry the board
for the rest i got ya coverd.
The TAD Connector is The TAD (Telephone Answering Device) connector is for connecting a voice modem and sound card If both your audio card and voice modem have the TAD connector
And for your motherboards first the 460 http://support.dell.com/support/edocs/systems/dim4600/en/4600i/index.htm#online_documentation & for the 170L http://www.fixya.com/support/p349168-dell_optiplex_170l_170l3ry9r41_pc/manual-14438
SOURCE:
Acer flat panel monitor with dell dimension 4600 desktop, i am having a resolution problem. Icons are blurry, or fuzzy. the computer does not have a DVI port to connect to the monitor. I have used only VGA...
the issue is most likely the resolution you set the panel to. also make sure you select a generic flat panel driver under the Display properties EXP: if your panel is a 17" Panel chosse 1a driver with a max resolution of 1024X768 @ 60hz to start and go on from there you will solve it.. let me know if you need more help.. Marcelo
Aug 06, 2011 | Dell Dimension 4600 PC Desktop
Can i change out the motherboard on my dell dimension 4600 and use the one from my optiplex gx 520 in place of it.
No you can't. The Optiplex system board is a BTX type, and the Dimension uses an ATX style. The BTX board was supposed to be the new standard, with the layout changed to improve cooling air flow. Unfortunately, the I/O connectors (keyboard, etc.) aren't in the same place as on ATX boards, and you can't just drop the BTX board into the same case. (This is one of the reasons the new design didn't catch on. Seems people didn't like the idea of shelling out for a new case as well as the board.)
May 28, 2011 | Dell Optiplex GX520 (XG309) Motherboard
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
What kind is motherbourd
The Dell Dimension 2400 motherboard is proprietary to the Dell Mitac Chassis. It should work in any Dell 2300/2350/2400/4600/4700 case. The main item is the Dell specific power/control panel connection. If you move the board take the control panel with it.
(Personally, it isn't worth the effort)
Jul 05, 2010 | Dell Dimension 2400 PC Desktop
Front Panel help for Dell Dimension 4600
Go to dell site and query for *********** board specs. Then query for the pinouts on the board. Or goodle dell optplex+motherboard+hardwire connections. good luck
Jun 17, 2009 | Dell OptiPlex 170L PC Desktop
Ethernet card
hi
yes the ethernet card is compatible
kind regards
RAhUL_hunk
Mar 10, 2009 | Dell OptiPlex GX260 PC Desktop
DELL motherboard drivers
if you want a driver for yourdell mother board you can download call the dell support centre they ll send you or else you can download through http://supportapj.dell.com/support/downloads/this is the dells site they ll ask about the model and service tags......
Mar 12, 2008 | Dell Dimension 4600 PC Desktop
Dell 4600 motherboard
That particular Dell uses a power supply with non-standard wiring. The plug is the same size as an ATX plug, but it's wired differently. If you were to replace motherboard & plug in the standard power supply, it would damage the supply, or the motherboard, or both. Also, the front panel plugs (for power & power LED & hard drive indicator) are proprietary as well. Ideally you should replace it with another Dell Dimension 4600 motherboard. I've found replacements for reasonable prices on some of the auction places on the web. I recently replaced a failed motherboard in my Dimension 8300 with one I got from a popular auction site, I think my cost was about $59 plus shipping.
The other option would be to remove the hard drive, video card (if any), and optical drives, and consider a 'barebones' package from various sites such as geeks or newegg.
Jan 05, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
7,255 people viewed this question
Ekse
Clive
Clive
