Question about Alpine CDA-9885 CD Player
Please help Can not figure out why my subs and amp will not power from the deck. i have music going to my stock speakers but not my ones in my trunk. Amp powers on, deck has been replaced with new one, all cables are good
  • jabuskey Mar 30, 2008
    I can not find anything that works on fixing this problem.
    The amp is getting power only when the remote wire and the RC connectors are plugged in. I can pull out the power supply to the amp and it will still be lite up as long as those other 2 wires are plugged in,
    We tested the amp and it is in fact pushing out everything it needs to, so we know that is not the issue,
    When i checked the outputs on the Alpine it was not showing anything. I called best-buy and they said that was an issue with this model sometimes. The exchanged it with no questions asked. They also tested the RC plugs in the back and said they were good.
    So i should be able just to come home and plug everything in. Well it still is not working.
    In fact i left it on for about 10 minutes and the amp was not even warming up.
    There has to be a setting or something on the cd player that i am missing.
    Genius:
  • 1,550 Answers
Estas seguro que tu amplificador esta funcionando bien ya que puede ser el causante si sus amplificadores de audio estan malos.Checa eso.
Posted on Mar 29, 2008
  •  Francisco Mauricio G
    Francisco Mauricio G Mar 31, 2008
    Checa el cable de la corriente que viene de la bateria en veces por no estar bien ajustado el amplificador no funciona
SOURCE:
My sound stopped working except the sub and amp.
If you have a little electronic know how... it can be a blown capacitor in the speaker. If you find it, solder a new one in and turn the volume down in the future. And look around for any signs of burnt insulation. Trunk amps are notorious for being insufficiently wired for power.
Apr 24, 2015 | 1998 Nissan Maxima
Stereo install yukon w amp and subs
Recheck your connections from deck to "non-sub" speakers. Are you using an adapter from deck to vehicle wiring harness OR are all wires individually connected?
Apr 09, 2014 | 2002 GMC Yukon
I bought a sony deck to replace the bose stock deck on my 1996 nissan maxima. I purchased the wiring harness and antena adapter also. I hooked everything up right and getting power but im not getting no...
each speaker in your car runs the wiring thru an amp. So each spkear has its own amp for the bose system. You can not hook up a none bose radio If you do you will need to run new wires and replace all the speakers. Sorry.
Jul 02, 2011 | 1996 Nissan Maxima
Where is best location to mount speakers besides trunk and trunk deck & doors?
Kick Panals are good, boxes are expensive though as they must be custom fit. Dashboard mounts, prolly only for componant speakers not subs. But if you wanna add speakers, you can always put more in the doors, trunk, or trunk deck to. Or replace your factory trunk deck, or door panals, and customize them to fit as many speakers as you like, have fun with it..
Oct 08, 2009 | Car Audio & Video
Subs not working.
blown sub if it sounds liek a cracking, with sub off, gently press the sub in, if you hear noise, its dead
Sep 23, 2009 | Car Audio & Video
I recently was trying to install a 10 inch pa sub with a 3/6 inch tweeter and in the process snipped the black and red wires connected the sub it did not come on I then snipped the blue and red wires in...
sounds like you blew some fuses replace them. then reconnect stock wiring. the get after market deck, amp, and wiring that in it's color coded so it no that hard to do.that 10 inch pa speaker pulls a lot power plus it 8 ohm impudence. your going to need at least a 200 watt amp.bridgeable.
or single channel.
Sep 20, 2009 | 1995 Ford Escort
I just got the Kenwood Sub KSC WA100 from my cousin with no electric wires or nothing so pretty much what all do i need and where can i find it i will be putting it in a 07 nissan sentra 2.0
Subs are subs, they come with no wiring. You need an amp and all necessary wiring to get it bumping. What type of deck do you have? Where will the sub be placed? In the trunk? Amp install is easy. Also suggest purchasing one of those amp kits for $20-$30, makes it a bit easier.
May 03, 2009 | Kenwood KSC-WA100 Car Subwoofer
What car amp to use to run 2 dvc subs
You need a stereo amp that can run 400amps
continous, with an output of 4 ohms. These should
not be too hard to find and they are getting smaller
all of the time. Make a practice look on ebay.
They give you pictures and you can check the dimentions first, so you know it can fit between
your two deck lids.
Apr 25, 2009 | Kicker CVR8-4 Car Subwoofer
Sub volume stays the same
in the back of head unit u might have 2 pre outs try swicthing them if u dont then on the amp u should have nobs turn them all the way up
Jun 16, 2008 | Kicker CVR12 Car Subwoofer
Alpine CDA-9885 CD Player Logo
48 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
