Question about Maytag Neptune MDG5500AW Gas Dryer
My dryer makes a very loud screeching while tumbling
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers is in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
Posted on May 13, 2010
Why does my gas dryer make a loud vibration noise?
Hey friend, I appreciate your post!
I understand that your Electrolux gas dryer is making a loud vibration noise and is also loud while tumbling. There are several components in your dryer that could be causing this noise. Based off what you are describing it might be an issue with your suspension rollers, motor, or pulley. Since it could be any of these underlying issues I would suggest getting a technician out to diagnosis and repair your dryer. Hope this is helpful. - Matt
Jul 21, 2014 | Electrolux Dryers
I have a GE electric dryer and it makes a horrible screeching noise when tumbling. it tumbles and gets hot but when trying to manually turn the drum it gives me some resistance. whats the making this...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 25, 2011 | Dryers
Otsein hoover nextr 7.5 tumble in one direction is ok in reverse it screeches very loudly.Could it be the belt or a bearing ?
Jockey pulleys are worn ...Not a major fault as its just noisy ..You will fine it get a a bit better as the machine runs...
Jan 29, 2011 | Dryers
The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Apr 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer screeches
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 14, 2010 | Amana NDE2330AY Electric Dryer
Loud screeching noise
The problem is usually caused by dry drum roller.
You need to remove the drum and lube or replace the rollers
Sep 24, 2009 | Hoover Dryers
Amana dryer loud noise
remove the lowe acesss panel( 2 5/16 screws) wiht the panel removed and a flashlight in hand, turn on the dryer and watch it tumble. you should be able to pinpoint where its coming from. its either the rear roller supports, the front drum glide assy's, or the tension pulley in ehich the belt its wrapped arund(develops a rut in which the belt has cut into it causing horrible screeeching noise, heck to replace all three of the components is problavle ony 50 bucks or so
Apr 23, 2008 | Amana DLE330RAW Electric Dryer
Dryer screeching when on
likely has a slipping belt , it will smoke before too long,
unless something got between the drum and door and is scratching .
Mar 22, 2008 | Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
112 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
