Question about Zebra TLP 2844-Z Thermal Label Printer
Labels are "faded" looking when printed. looks like you need to change ink but obviously there is no ink
  • 53 Answers
Raise the darkness in the printers driver. Goto printers and faxes then right click on your zebra printer driver. Left click properties and then left click the advanced tab, then left click printing defaults button . Designer driver darkness is right there. Universal driver you click a few levels deeper by clicking device options and then head settings to find the darkness setting.
Posted on May 19, 2010
  • 4,234 Answers
Is this unit in thermal transfer or thermal direct mode? Depending upon the usage of this machine, perhaps a new thermal head is required. If thermal direct, try a different roll of labels, it is possible to get a bad batch. In thermal transfer mode, the tape could be bad as well. Try a new one to test.
Let us know what you find.
Thanks,
Dan
Posted on May 12, 2010
Lexmark Z715 printing faded color
you might need to go to the IBM website and find instructions for your printer and look up how to clean the printheads on your printer or just look up the manual that came whith the printer if it did come whith any
May 16, 2010 | IBM Lexmark Z715 InkJet Printer
The ink seems to be fading, but there is no ink, so what the solution?
There is no ink, toner, drum, ribbon or anything else. The labelwriter uses a fixed thermal printhead to print onto heat sensitive labels. This problem on the handheld labellers is almost always an early indication of low batteries.
But this labeller is only powered by the mains, so isn't the problem here. Assuming you using genuine labels then the only likely explanation is that the printhead needs cleaning.
If the 'fading' is happening unevenly across the label then this is probably the likely problem so you need one of these:
Dymo Cleaing Card
If it's not that then it's most likely a hardware fault of some kind, either with the printhead or the power supply. There's not really a lot that can go wrong with these machines...
Mar 29, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
Color photos printing very faded
Some nozzles could be burned out on the printhead, and you need to make sure you have no photo inks installed where regular inks should be. Photo magenta prints much lighter than regular magenta.
Aug 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Part print
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
 Thanks,
PREM
Mar 22, 2009 | HP DeskJet F380 All-In-One Printer
Faded prints off canon p100
it could the problem with clogged print head try to clean the print head
Jan 29, 2009 | Canon Office Equipment & Supplies
Ink is fading on my qx50
Dymo Labellers don't use ink, they are thermal printers. When the print fades it usually means the batteries are running out.
Jan 24, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Black print is faded when i print
Jan 10, 2009 | HP Photosmart C3180 All-In-One InkJet...
Possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
May 02, 2008 | Zebra Z4Mplus Label Printer
Black ink on glossy paper looks like leopard spots
printer need head cleaning , after cleaning check nozzle , if solid color appear w/out space on black color it means good and clean nozzle.
Dec 27, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Zebra TLP 2844-Z Thermal Label Printer Logo
313 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
