Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Fi light help why does the f1 light beep and how can i fix it?
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&%@&^
Posted on Sep 21, 2010
Oven temperature reading says FI and is beeping.
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
Sep 24, 2011 | Kenmore Kitchen Ranges
Bike back fires and the f1 light comes on on the cluster panel as well as bike dies
The F1 light is the FI fuel injection light. Your bike needs to be diagnosed and scanned by your dealer or trusted mechanic. There is a problem with your fuel system and a code has been registered, your bike won't start or run correctly until your mechanic has scanned, fixed and cleared the code.
Sep 11, 2011 | 2003 Honda VTX
I just bought a 2008 Suzuki B-King and it keeps flashing the fi code and the fi light is on. It has aftermarket exhaust on it, how do I stop it from flashing because it wont let me see the trip meter at...
Take it to the shop and have them read the error code. The flashing is an error code and wont stop till you fix the problem or shop resets the code for you... That is my experiences with these issues....
I hope that this helps you and please do not forget to rate/vote and place a testimonial on my advice.
Wicked Angel
Nov 19, 2010 | 2008 Suzuki B-king
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
I have a Fisher Paykel dishwasher that is beeping
you have to remove the bottom drawer ......
f1 fault is a fload fault
e-mail me and ill give you my cell number
cause im factory cert. for this company
Jun 23, 2009 | Dishwashers
03 gsxr1000, stalls when down shifting, F1 light is on.whats the fix?
The FI light is an alert to you that the computer has found a Fuel Injection problem in the engine. The dealer can read the code and tell you what is wrong. You can then decide to have them fix it or do it yourself.
A “very helpful” rating for this answer? Thanks!
Jun 11, 2009 | 2008 Suzuki GSX-R 600
Fi code washer wont stop beeping
See this site for a full explanation of how to fix this problem, I don't want to type it alll again. F1 error code is 'overfill' most frequently due to a clogged drainhose. If not see here;
http://fixitnow.com/2004/10/appliance-repair-revelation-fisher.htm
May 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
Beeping sound showing f 1
HI thanks for your question. F1 means that the touch pad is faulty. it says to replace the touch pad. thanks .please rate my answer thanks.
Oct 07, 2008 | Jenn-Air JJW8530C Expressions Collection...
Error code F1
I had the same problem and found this post:
http://fixitnow.com/wp/2006/03/11/maytag-amana-jenn-air-and-magic-chef-range-f1-codes/
The oven had been cleaned earlier in the day and the touch pad ribbon connector was shorting. I cleaned it with rubbing alchohol and blow dried the whole board for good measure. Hooked everything back up and haven't had a problem since.
Jun 08, 2008 | Jenn-Air JJW8230D Electric Double Oven
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal De
