Question about Nespresso Le Cube
How do I reset my Nespresso Le Cube to factory settings?
3 Suggested Answers
SOURCE: After descaling le Cube two flashing buttons won't stop so can't
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
Posted on Feb 05, 2011
SOURCE: I have a Nespresso Le
how can I reset my Le Cube? Volumes have changed.
Posted on Feb 06, 2011
Nespresso magimix
Check the relay on circuit board
Jul 20, 2014 | Nespresso Le Cube
I have a Pixie but the large cup does not shut off
Hold both buttons down while you turn the machine on - for 5 seconds - which will reset the machine to its factory settings. Then you can reprogramme to suit your taste, as in the instruction book. Good luck - hope this helps.
May 27, 2014 | Nespresso Le Cube
Espresso and Longo buttons flash simultaneously and continuously
Try holding both buttons down while you turn the machine on until they stop flashing - usually about 5 seconds. This will reset the machine to its factory settings. Hope this helps.
Apr 06, 2012 | Nespresso Le Cube
Very slow water flow, barely filling tea cup
It could be a problem with an air bubble or with scale deposits.
It is recommended that you first run a descaling cycle using the proper descaling product. Do not use vinegar as it can damage your machine. Information on descaling can be found here:
http://www.nespresso.com/fileadmin/shared/_img/manuals/Nes_DescalingKit_CBU_internet_081216.pdf
To find more help with your product go to the website below:
http://www.nespresso.com/#/no/en/coffee_machines/selecteur_gamme/machines-le-cube/le-cube-nespresso-auto-d180---110-v-1
Feb 28, 2011 | Nespresso Le Cube
Hi, My Nespresso LeCube doesnt make full espresso or coffee anymore. It only fills the espresso cup less than 1/3 and its very diluted. Appears the rest of espresso falls into the drainage area. I have...
I had the same problem. First, unplug machine for two (2) minutes. Then re-plug and as on/off switch is flashing- press and hold large cup button for 3-5 seconds (no light should show/flash from this button while you hold it down. The on/off will continue to cycle through its normal startup, after it completes you should be reset to factory settings and good to go. Good luck to you, this maneuver saved me.
Sep 11, 2010 | Nespresso Le Cube
Le Cube: Water does not flow after tank in Le cube ran dry....
Open the lever (the one on top of where you put the pod, and keep pressing it backwards until water comes...
May 18, 2010 | Nespresso Le Cube
Where can I download the manual?
The manuals are available on the Nespresso website (www.nespresso.com). Click on the "machines" section, and then choose the le cube. Click on the details page (https://secure.nespresso.com/precom/sima/fiche__NESPRESSO_Le_Cube_D185__N_D185_1_us_en.html) and you should see the link for downloading the manual. You can also download the descaling instructions as well.
Aug 06, 2008 | Nespresso Le Cube
Nespresso Le Cube Logo
1,781 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
