Question about Polaroid FLM-4234BH 42 in. LCD HDTV
Power is on (Blue light) but the screen is black. Does not display picture.
    President:
  • Polaroid Master
  • 749 Answers
There are two likely options: either one of the backlight inverters has burned or the power supply has a puffed cap and doesn't provide voltage for the inverters.
The simplest way to tell is to use a voltmeter and find if power provides 24V to inverters. It's easy to see where, there are at least 5 wires for ground and another 5 for the 24V line, so it's a no brainer to find them,
If there is 24V on the inverter then either the master or the slave is burned.
Chances are good you may be able to find which one by testing the fuses on them.
Finally, the master backlight board is 6632L-0346A and the slave is 6632L-0347A.
Hope this helps!
Bobby @ CoppellTVRepair
www.coppelltvrepair.com
Posted on May 12, 2010
3 Suggested Answers
SOURCE: black screen,no picture just a sound.not even menu bar displays
I had this same issue a year ago and I have it again. I was told it is the light. The company sent me a new one I installed it easily. Worked fine I am not sure why mine died so fast
Posted on Jan 03, 2008
  • 33 Answers
SOURCE: blue light blinks three times
for more info on this set please check out http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
if will tell you how to trouble shoot this tv. these tv's are known for two caps in the power supply to go bad and they need replaced then you have to test the sdr boards if they are bad you need replacement boards or you can send them off to be repaired. the link for the repair guy is on the page. this guy also sells the repair on ebay but if you contact him directly i beleave the price is lower. just tell him you were send over by home theater shack.
If your handy you can repair this tv for not to much money. you need to buy two caps and maybe send one or both sdr boards out for repair. I would say anywere from 50 to 125 dollars you can repair it yourself. As long as no other parts are bad.
Posted on Feb 22, 2011
Screen problem
I have the same problem. rca 26lb30rqd. The red light is on (steady), and when I hit the power button, the blue light comes on for a second, then goes black, w/ no display. Before this happened, the display was extremely bright with ghosting. The picture was un-viewable. Did you every figure out the problem?
Mar 15, 2014 | RCA 26" LCD HDTV/DVD Combo 26LB30RQD - ON...
Screen black
Here's the test to determine which board is faulty. With the TV on, as usual, shine a flashlight on the screen to see if there is a faint picture. If there is, then the ballast board for the backlights is bad. If there is no visible picture, then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 13, 2017 | Hitachi P50H401 50 in. Plasma HDTV
I have a jvc lt-26a6asj tv blue power light is on but no picture just black screen when turn on and off get a flash of picture but then goes to black screen
hi, the most probably is broken one of neon lamps that illuminates led display .you can check that when you turn it on and flashes, see if one side of screen is brighter then other. also,it can be that power supply in led display got weakened and haven`t got enough power,but that is job for service like any bigger failure.
this is not the only answer,there is always several solutions but you have to give more informations about malfunctions. good luck!
Feb 27, 2011 | JVC Televison & Video
When I connect my monitor to my lab top the green power light comes on then turns orange and I get "no signal" message on the monitor
you may need to tell the lap top to display from that screen the new screen has no image or signal so goes to sleep to save power.on your lap top try the (FN) key on your laptop then select a blue picture on the keyboad of to squears one black one blue this will alter the display.OR in windows look at Start>controal pannel>display
Jun 03, 2010 | Sharp LL-173C-B (Black) 17" LCD Monitor
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Oct 18, 2008 | HP vs19 (Silver) 19" LCD Monitor
A17w221 goes off automatically with power on
I have the same problem. The next stage is that the picture won't come on at all and the blue light will constantly blink. I think the light source is bad. Noit sure though.
Mar 25, 2008 | Envision A17W221 Television
Black screen,no picture just a sound.not even menu bar displays
Sep 09, 2007 | Televison & Video
Polaroid FLM-4234BH 42 in. LCD HDTV Logo
619 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
