Question about Gateway Essential 500 PC Desktop
One speaker has some volume the second speaker has static
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 121 Answers
Uninstall the sound driver from device manager and restart the computer. it will reinstall the default driver on the computer. also check the properties of the sound in the control pannel. double click the icon in the properties and sound window will open then check the settings for the left and right speakers. check the sound wires of speakers if its a external speakers.
Posted on May 13, 2010
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
My pc left speaker does not work. but in other devices speaker works
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
or if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Aug 21, 2012 | Intel Desktop Board DG41WV Motherboard
I have the Bose Companion 3 Series II speakers. I ordered them through the Bose website. However, I continuously hear static. Mute, low volume, with music, etc. I hear static noise. The only way to...
I have had totally the same problem before, and I have discovered that it is actually because of the electric current running through the speakers when the volume is low or muted.
I am afraid to tell you that the only solution to this problem is to raise the volume, as it is not a malfunction in the speakers but in the electric current running through them.
Good luck.
Dec 16, 2010 | Bose Companion 3 Series II Multimedia...
Basically, I've noticed a fairly faint static noise while listening to music at about 30%-40& with the Logitech z-2300's. I dont know if the problem persists when the speakers are any higher because I...
Most speakers I have owned or listened too have a faint buzz or static to them. If you are using a computer turn up the volume on the computer all the way and then you should not have to turn the volume knob on your speakers past 20% that's what i did with mine and they sound fine. If you are using something else like an i pod or something like that make sure you turn the volume on the device all the way up to ensure you don't have to turn the speakers up that high. If that's not your problem then i don't know.
Dec 12, 2010 | Logitech Z-2300 Computer Speakers
Static in speakers even at minimal volume
try to change the location of you desktop PC...because some static sound is came from the other device creating static...like lantern with ballast ..etc
May 26, 2010 | Dell 5650 Computer Speakers
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
May 07, 2008 | Logitech Z-5300 Computer Speakers
2001 ford explorer sport trax
probably exposed wires are touching something or they werent spliced very good,id check every point wher the wires were spliced together
Mar 25, 2008 | Bazooka BTA10100 Car Subwoofer
Static from left speaker when adjusting volume control
You might try replacing the connection cables. Old cables can cause the problem you have experienced.
Dec 26, 2007 | Audio Players & Recorders
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
Gateway Essential 500 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
