Question about Dell Inspiron 1501 Notebook
My lan doesnt work but the wlan is ok - Dell Inspiron 1501 Notebook
  • 129 Answers
Please explain your problem.
Go to Control Pannel then network and internet connections now see if your LAN connection is not disabled or is it listed?
if this is disabled then you have to right click and enable it. its better to restart after this.
Posted on May 12, 2010
EdiMax Br-6482nS doesnt give internet
A router is only used to connect devices together in a LAN (local area network). In order to get out to the internet you also will need a modem (cable or dsl depending on your service) You will also need to pay for service through an ISP (Internet Service Provider)
May 02, 2013 | Edimax Computers & Internet
Everything was finewith wireless until we pluggd ethernet cord into back of siemens for xbox 360 now computer (wireess) doesnt work upstairs help
check what cable you plugged into the xbox...and be sure is not the main internet cord that it supposed to be in the wlan port of the router ...and get a cable from one of the router's LAN port into the xbox..and leave the main one into the wlan ..this way you will have wireless ...if the configuration on cables is ok ...get into the settings of the router from the admin computer the settings were made in the first place ....and see whats wrong with the wireless settings ..they may be disabled by mistake ..or another odd reason ...and enable the wireless transmitting again ..
Mar 21, 2011 | Computers & Internet
Were is the wireless turn on switch?
It appears that there isn't an external switch to turn the WLAN off on the Everex NC1500 laptop (click here for the full manual). Here is a link showing you how to disable and enable WLAN card in WinXP (click here) if this is what you are trying to accomplish.
According to the manual (if your wireless isn't working) you must first install the WLAN driver before using the wireless connection. Info: "Wireless LAN module is similar to LAN module. You need to install software driver before using it. Please refer to Appendix B on how to install the driver." Appendix B INSTALLING THE WIRELESS LANDEVICE DRIVER Please follow the procedures below for installing the Mini PCI Adapter driver: Installing Wireless LAN driver for Windows XP 1. Click the Start button and then click Run. The Run dialog box appears. 2. Click Browse button and specify the directory as "E:\Drivers\Winxp\Wireless LAN\setup.exe" 3. Click "OK" to implement the setup program to install this driver. 4. Click "Next" twice to continue the installation.
Hope this was helpful.
Feb 01, 2011 | Everex StepNote NC1500 Notebook
Hi, I have a dlink DSL-G604T router, wlan light not on.
Hello there!
Only thing that can cause your wlan light not working consistantly or with some blinks (which is normal thing) is bad lan cable which leads from your ADSL modem to your wlan entrance on your wireless router, please check that cable in order to fix that problem. Cable doesnt need to be coaxial so it can have 2 different lan sets (2 poles of exits male and female exit). Thats it ! =)
Please rate solution! =)
Sincerely
Aleksandar Adzic
Apr 15, 2010 | Computers & Internet
3COM WLAN not working
Might be time for a new device. My favorite is the LinkSys brand.
Dec 26, 2009 | 3Com OfficeConnect Wireless Router
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
Jul 08, 2009 | Nokia E61 Smartphone
I have a problem with my unit amilo xi2428 in which lan port is not being recognized by the computer, i mean everytime i connect a lan cable it just doesnt appear any connection and when i run the...
i´ve the same problem, i tried the newest driver from fsc download center. the installation was successful but still there´s no lan adapter.
any ideas?
May 02, 2009 | Computers & Internet
WLAN does not work
Can you try and reset the router once. I guess that should help . There should be a reset button behind the router and the reset procedure should be present in the manual
Jan 11, 2009 | SMC Barricade g SMCWBR14T-G Wireless...
Router problems
Check with this tip.
Check if router is working on Net using a Lan cable to connect your PCs and check if you can browse from PC..
If Internet OK check if radio is enabled in your Belkin router.
Then check if your SSID broadcast is enabled in your router.
Check if Router and PCI Wlan adapter are on same WLAN standard A,B, G, or N and disable every security protocol (WEP or WPA)
Define a new SSID name and check if you see your Wlan on PC.
Restore your security as soon as connection established.
Jan 05, 2009 | Intel PRO/Wireless 5000 LAN Access Point...
WLAN WONT CONNET
Hi, Hope this will help u..
1>connect LAN and check the WLAN light on wireless router It should be ON and solid, If not the you might need to reset the router
2>On your laptop click on start go to run (in case of XP) or go to start then search box (in case of vista)
3>type services.msc
4>For Xp check the wireless zero configuration service should be automatic and running
5>For vista WLAN service should be automatic and running
6>then go to start > run ( FOr XP) or start >
>search box(in case for vista)
7>type ncpa.cpl >click on OK
8>right click on wireless network icon and click on view available wireless networks.
9> Choose your network and click connect,
10> If it asks for WEP key , It might be written in your router.
If this doesn't work, you can contact your Internet service provider.
Dec 27, 2008 | Computers & Internet
Dell Inspiron 1501 Notebook Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
