Sony NWZ-E436F MP3 Player Logo
Posted on May 12, 2010
It is stuck on creating library. I have pushed the reset button and nothing When I connect it to the computer it is not recognized either
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on May 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
3700
Points
27
Well, Is it fully charged?
See, when chargible stuff aren't fully charged, they tend to freeze or even tend to loose funton of their buttons. Try putting it on the charger and wait till it's fully charged
1helpful
3answers
Iphone6 How to remove waiting apps
Hard reset your iPhone and reboot it, the app that is stuck at "Waiting" should be gone from the springboard. You can then download the app again from Appstore.
How to hard reset an iPhone: Press the home and power button simultaneously for 10 seconds to switch off the iPhone. Then, press the power button to reboot.
Oct 28, 2014 • Cell Phones
3helpful
My Sansa e200 series is stuck on the splash screen and would not response on any or cannot be recognized by computer. Please assist
Battery and Black screen Blue ring: Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery also push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen, Black screen Blue ring ) and put the back on.
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard thIs should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize IF not try a laptop.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
RESET: Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings.....
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.
This is what it states in the manual for the 260 sansa Page 29
Recovery Mode also resets system settings when unplugged...
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
and install the software before you recover
I ADDED SONGS TO MY COBY MP815 USING WINDOWS MEDIA PLAYER AND NOW IT WONT TURN ON. I PLUG IT INTO MY COMPUTER USING MY USB AND WHEN I UNPLUG MY USB FROM THE MP815 THE SCREEN FLASHES WHITE FOR A QUICK...
Assuming the player is charged. (For charging always connect directly to the computer, not through a reader or hub).
When buttons on the player do not react, reset the player:
Disconnect the player from the computer.
See that the HOLD button is not engaged.
Gently push the RESET button on the rear side: use a narrow pointed
object, like a paperclip.
Did synchronization of the songs in Windows Media Player fail ?
For transferring songs, check in Windows Media Player:
1. The player is detected in Windows Media Player 10 or higher.
2. Setup the Library / Add to Library: add the location of songs you want to transfer in the library.
3. Create Playlist; give the list a name and put songs in a playlist
4. Sync Playlist: transfer the list of songs onto the player and wait for the message until you're allowed to disconnect.
1helpful
My computer won't connect to my printer. When I turn on the printer the computer says it doesn't recognize the device. The drivers are not installed, but the computer will not allow me to install them. The...
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
3helpful
My Sony Walkman NWZ-E436F shuts off after creating the library
Hi I had the same problem and I finally figured it out.
First you will have to try to connect to the computer by pluggin it in and reseting once the computer recognizes it you should be able to look at the files.
If you are able to get the device to this point;
1. create a folder on you computer it could be in you desktop or document and name it something you would remember to go to. I named mine SONY.
2. copy all the folders from your WALKMAN to this folder;
3. delete all files from your WALKMAN there are some files it will not allow you to and just hit SKIP.
4. download the Firmware update (1.02) from the SONY Suport website: http://esupport.sony.com/US/perl/swu-list.pl?mdl=NWZE436F and select your computers operating system and download the file.
5. Once you download it run it and it should re-install all the necesary files back to you device.
6. Re-start the WALKMAN and it sould work just fine now you can go back and add your music files and photos, etc...
Good luck this worked perfectly for mine.
My computer doesn't recognize my itouch
Try a hard reset of your device:
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
window.google_render_ad();
5helpful
3answers
Sony Walkman NWZ-S615F problem detecting and syncronizing
I had the same problem. One day my Mp3 started acting weird and said it was not recognizing the files and that i needed to re download them. Try plugging it up to your computer while its charging and hit the power off. Then reset your mp3 with the button at the bottom and it should recognize it.
4helpful
5answers
Mp3 stuck in rebuilding library mode
hello guys sorry to hear your problems i have same problems too. Ok first plug ur zen player (mines V PLUS.. heheh) to ur pc then hold play button then keep pressing the reset botton until it turns on RECOVERY MODE then select YES to all (clean up, format, reload firmware) then download the RECOVRY TOOLS at creative site install it then plug ur zen player and run the recovery tools (cross ur finger) hopes it works mine a big smile hehehe email me at [email protected] if it works..Gud Luck guys
3answers
Won't charge and computer will no longer recognise
try pushing the reset button in the back of the player
Recovery Mode
  • Detach your player from the PC if it is connected, and turn off the player.
  • If the player stops responding, you can reset the player. To reset the player, gently insert a thin object into the Reset hole located below the power switch.
  • Press and hold the Play button while powering on your player.
  • When the player displays the Creative logo, release the Play button.
  • It will display the following options:
    Clean Up Scans the player and removes invalid links from its music library.
    Does not affect music files themselves.
    Format (All) Caution! Erases all content!
    Save a copy of your player's content before formatting.
    Reload OS/ Firmware Caution! Erases your player's firmware.
    DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
    Reboot Reboots the device.
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    John
    John
    ZJ Limited
    ZJ Limited
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
