Question about Singer 7462 Mechanical Sewing Machine
How do you remove cover from Singer 7462
How do you remove case from singer 7462? I have everything loose except getting it over thread tension control knob
I found that by turning the machine over on its back I could lift the front cover from the bottom and get it over the tension knob.
Posted on Mar 29, 2008
Light bulb
My brother LS 1217 sewing machine under thread is very loose. I tried all options like adjusting the wheels, tension, rethreading and played with the machine. No use.
Jun 15, 2013 | Singer 7462 Mechanical Sewing Machine
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
Bottom tension too loose.
Is it looping on the bottom of the fabric? If so this is a top tension issue, you need to check some things,
-make sure you thread the machine with the pressure foot up ( this allows the tension discs to open up so you can pull the fabric away from the machine with the foot up and allows the thread to get to bottom of the tension discs)
-make sure your tension settings are set to the medium setting. (Usually 4 or 5)
If this still does not help, then turn the top tension knob up (from 5 to 6,7,8,9....)
-If that still doesn't do it, your probably need the tensions reset. Let me know if you need more help.
-Chris
Jun 05, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
Fixing the bottom thread when it sews loose
It could be that you threaded the machine with presser foot down.
When the foot is down, then tension control is closed and the thread cannot seat for proper control to the needle.
What appears to be a bobbin problem is actually the top thread not having the tension needed (thead is not where it should be within the tension control) to form a stitch.
Apr 25, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
Tension problems
Hi, check that the thread tension knob makes only one rotation from 0 to 9 and stops at each ends, see that it moves in and out as you increase or decrease the tention, see that the small tension wire to the left of the knob is still in place, in any of these fail you need to replace/repair that assembly.
Aug 11, 2009 | Singer 7462 Mechanical Sewing Machine
Sewing machine dressmaker model 300z
i think you have not looped the thread around the tension on the top before putting it onto the bobbin. you need to wrap the thread in a circle around the sphere near the regualr threading lines.
Nov 10, 2008 | Singer 7462 Mechanical Sewing Machine
Singer Starlet 353 Thread tension
you need to do a tension assembly check.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air. The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
sewman7
Nov 07, 2008 | Singer 7462 Mechanical Sewing Machine
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
I am sewing on demim. The thread is inches loose on the back side... it is terrible. Not really sewn at all. I have changed the tension on top several ways but it does not seem to make a difference. I...
The manual can be downloaded for free from Singer's web site...
Are you seeing loops of the upper thread on the bottom side? If so, then the bobbin tension is too tight, or the upper tension is too loose. The threaded shaft on the upper tension might have stripped, leaving you with no adjustability.
Sep 16, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
458 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
