Question about Jenn-Air JLG7130A
My rotisserie burner is not working properly it will light but after a few minutes the flames will start blowing out of the top of the burner. I am using LP gas model #720-0720 Serial # 001315A purchased only 6 weeks ago happened 1st time I tried to use it.
  • Jenn-Air Master
  • 19,396 Answers
Hi.
It is either a faulty valve or a defective gas pressure regulator.
If you are located in US you can call BBQSource store to get the replacement part. Here their toll free number: 1-888-252-7686:
Regards.
Posted on May 12, 2010
I was just wondering my rotisiree burner dosent work .. please help asap! thanks
If it is not igniting and hold the flame and getting red, it could be that the burner is dirty and clogged or the thermocouple that keeps the burner lit has failed.Please keep in mind, when lighting an infrared burner, you must hold the burner control knob in for several minutes. At least until all the ceramic plaques are glowing brightly. if the igniter won't light it, try match lighting it, while you hold the burner control knob in.
Most gill manufacturers recommend lighting and burning the infrared rotisserie burner on a regular basis, whether you use it or not,. Doing this helps to keep the burner clean.
I hope this has helped you and thanks for choosing FixYa.
Sep 14, 2011 | Grilling
Flame does not stay on Rotisserie Burner grill but jumps back into the throat where the air mixes with the propane gas. What's wrong and how do I fix it?
If it's windy outside when this happens, the wind is blowing the infrared burner out. Especially if the hood of the grill is open. The Rotisserie should only be used with the hood closed.
Feb 09, 2011 | Grilling
CalFlame 4-burner convection BBQ rear rotisserie burner does not work. Converted to natural gas. There is a spark but gas will not ignite. Held match to burner and it would light but would go out when...
Check the air shutter adjustment on the rotisserie burner. It may be starving for air. Also make sure the burner is properly positioned over the orifice. When it was converted, it may not have been put back into place correctly. Also, it's possible the orifice may have been re-drilled out at the wrong size for natural gas. If you know the rotisserie burner BTU rating, I can look up the correct orifice hole size to check if it's right. Douglas
Sep 12, 2010 | Cal Flame 5-Burner
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
My gas house heater turns on, but turns off in a couple minutes. The heat never starts to blow out. Do you know what the probem may be. The piolot light is light and I just replaced to batteries on the...
It could be a few things, dirty pilot assembly, dirty or bad flame sensor or a bad gas valve or loose wire on the gas valve. Watch the flame as it lights to see if all the burners light. If not you will need to clean the burners and flame tray that spreads the flame to all burners. Good luck!
Nov 11, 2009 | Honeywell Programmable Thermostat Heater
I have a Intertherm furnace model MMHA with United tech controller 1018 HSI. Flames starts up , fan runs but flame goes out and restarts after a few minutes. Keeps doing this, I don't see a proof of flame...
Maybe. There has to be some sort of flame sensor with this HSI module. Look on the wiring diagram for where it may be. If this model has a pilot that starts before the burners, it may be part of the ignition electrode or glow bar. If the burners just light, look at the far end of the burner box to make sure the flame is traveling down the entire length and hitting the sensor. If you find it, clean it off with a small tooth brush. Blow out the flame rail where the flame travels from burner to burner. Clean off the pilot assembly if it has one.
Oct 17, 2009 | Heating & Cooling
Jenn Air 720-0061-LP Gas Grill Rotisserie Problem
Hi all ,
I just bought a jenn air 720-0336 gas grill from bj's . the rear rotisserie burner would stop working after a few minutes .
hear is the deal , the rear inferred burner gets to HOT . they did not put any insulation between the ceramic blocks and the metal bezel.My fix was to remove the unit , drill out the 8 rivets holding the bezel on , carfully remove the bezel and install a fire proof gasket , i was abile to find the proper stuff at my local coal / wood stove retailer.it comes in a white sheet about 1/8 inch thick .
use steel rivets to reassemble . good luck . this took a week of trial and error to figure out .
Aug 02, 2008 | Grilling
Ducane 3400042 lighting problems
Good answer... but remember (if you have the regular burners on... The Rotisserie will not light.) 1. Cut all knobs off... Then push and hold in Rotisserie button as you turn to high.
2. Press ignition button, until you hear rotisserie ignite. 3. Keep holding in the rotisserie button until the thermostat realizes the gas is on and burning. (IT must get hot enough to keep gas flowing.) Hope that helps, Dave
Apr 08, 2008 | Ducane 30400040 Stainless Steel Grill
Stove top difficult to light
your gas jets are dirty.. clean them with a toothbrush (after everything is cooled down).. you can use the selfclean to clean the iron pieces that cover the burners..
be careful with kitchen aid self cleaning.. there is a known issue with the thermal fuses blowing quite easily on most self cleaning cycles..
good luck
tpug
Feb 21, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Grilling Logo
297 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
