Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
HOW TO TEST IGNITION COIL ON A POULAN CHAIN SAW MODEL 2000? ALSO WHAT IS THE AIR GAP ADJUSTMENT FOR THE SAME?
    President:
  • 2,220 Answers
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when the flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 12, 2010
  • 4 Answers
0.015 0.020
Posted on Apr 27, 2012
There's 2 sets of numbers on the coil. The top i know is a part # but not sure about the bottom it's MA-15 1435 it's a Walbro coil
Rick, easiest just to order a coil by using make and model # of the chain saw.
MA 15 does show up a replacement Walbro coil.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Chainsaw Ignition Coil Test
Poulan Chainsaw Ignition Controls Parts
Poulan IGNITION COILS
Poulan
Apr 18, 2016 | Poulan Garden
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
How do i adjust the module-ignition on poulan pro chain saw model #PP4218AVWhat's your problem?
are you talking about the magneto to the flywheel gap i just use a piece of paper between the two and tighten it
Apr 07, 2012 | Poulan Pro Chain Saw 46cc 20"
Poulan chain saw factory spec for air gap ignition magento model 1175
hello,, the factory air gap is 0.008 to 0.010 depending on saw,,
Feb 18, 2012 | Garden
Saw will not run or start...set ignition module gap, disconnected kill switch wire because there was no spark...Put in new spark plug, got spark..Primed for gas and set choke as per instructions...Would...
Often the cause is a failed fuel pump diaphram. Rebuild the carb... kits about $20. The diaphram works from engine vacuum pulses. Also the little flap type check valves go bad... the ethanol in gas doesn't help this problem...
Sep 03, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
What is the gap for the ignition module on a poulan wild thing chain saw?
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
OPERATE
If you have not already, change the plug first and try it (very cheap insurance). If problem persists try this, it even checks the wiring and ignition switch:
If asking about ignition coil gap, an index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
If I completely missed the problem you are having you can reply below with a little more information and I will try again. If you need the part number of a replacement coil I need the model and serial if a Poulan to give you the correct answer.
Jan 02, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is distance from coil to stator 14 in. poulan chain saw
I think you are asking for gap between the fly wheel and the ignition module. A business or index card works great. 0.1 - 0.3 mm. GL
Lou
Oct 09, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
4,408 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
