There is an adjustment on the side of engine but don't know where it is supposed to be set
SOURCE: I have a model # RY39500 ryobi hedge trimmer 2
Sounds like the air screws need adjusted on the carburator. If there are 2 the one with the L above needs to be turned althe way to the right but not to tight and then backed out 1/2 turn to left. The one with the H anove it do the same except back it out 1 and 1/4 turns to left. If it only has 1 screw dot he same but back out 2 complete turns. Hope this helps?
Ralph at [email protected]
Testimonial: "Thank you, worked great!"
SOURCE: Gas Trimmer will not stay started
My straight shaft trimmer will idle but dies when the I pull the trigger.
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
SOURCE: Ryobi bc30 gas trimmer wont run full speed will
I have the same issues. I think the solution is to toss it and buy a real one from an actual lawn care dealer that sells quality brands. Yes, they will cost about $200 and up, but it's worth it to have something alot more reliable, and can be worked on when needed. I know I have wasted more than that extra $100 in time/effort with this thing, and I still plan to buy a new one. So now, that quality trimmer will cost more because of the money I wasted on the Ryobi in the 1st place.
