Question about LG VX5500 Cell Phone
White screen I only have a white screen. the phone works.
  • LG Master
  • 6,993 Answers
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
I wish you good luck.
Posted on May 12, 2010
Blank and white screen solution
Hi,there are two kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your phone am sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to the model of the phones care center to fix you problem...
And also flex can make screen go blank and or white.(if it is a flip phone)The flex is a connector that connects the screen to the phone board of the phone.That can also be the cause, when the flex is damaged,it can cause blank and white screen display .
i hope ,i will help you ,thanks for trusting fixya...
Sep 16, 2010 | Cell Phones
My samsung gravity screen is white, when its on you can only dial a phone number and call but the screen is still white no matter what. ive turned the phone off took out the battery, but it still doesnt...
The problem with your phone screen is that the screen of your phone is bad that is why your phone screen is white.
All you need to do now is to get a brand new screen on your phone and you will see that your phone screen will start to display.
I advice you go with the phone while going to get the screen in other to get a the exact screen and a working screen.
Replace the screen of your phone and your phone screen will start to display.
Take care.
May 16, 2010 | Samsung Gravity SGH-T459 Cell Phone
My samsung screen is white but it works ive tried everything, this hbas happen before screen going white and the battery had to be without juice to come back. it works but ithe screeen is white
hi, the main reason the screen turns whits is due to the thin ribbon that sends the data from the circuit board to the screen being damaged what happens is that the thin copper wires that are inside the ribbon ware and then break causing a short to the screen and this is what turns the screen white. this happens on most flip and slide phones as the ribbon moves when you slide or flip the phone so over time it becomes brittle and you lose the connection and this turns the screen white.
sometimes it will right itself if you open and close the phone a couple of times but this wont be a long term fix how ever it may be that bad that this will no longer work, its not expensive to get this ribbon replaced but taking you phone to a small phone shop would be your cheapest option.
May 14, 2010 | Sony Ericsson K800i Cellular Phone
White screen of death?
Hello
The white screen of death is a flex problem.
The flex of a phone is what connects the screen to the board of the phone. it is found in most flip and slide phones.
When you flip and slide these type of phones after a while the flex gets weak and that causes the white screen you see.
The only solution is to have your flex changed,that will definitely solve the problem..
Goodluck
Feb 19, 2010 | Motorola Mobility Rival A455 Cell Phone
My N72 is not showing any display... just a simple white colour screen
Did your phone drop on the flow? Is it just showing white and still works ?or Display white screen and not working?
For a phone to display a white, does questions need to be answered..
If it fell on the flow it's usually a screen fault and it needs to be replaced.
If it didn't fall down, but displays white screen and nothing function,it a software faulty needs a memory restoring..
If just showing white screen and you still can make calls with it, then it's screen fault needs to replace..
Feb 11, 2010 | Nokia N70 Cellular Phone
Main screen display problem
dear,
is it completely not working.. is it white screen or something else.
if the screen is white then it can be issue directly related with the screen itself but if it doesnt show white then the problem can be with the other circuitry..
regards,
Jul 18, 2009 | Nokia 6085 Cellular Phone
My cell w550i shows white screen no boot screen
Dec 08, 2008 | Sony Ericsson W550i Cellular Phone
Blank white screen
It seems to be ur lcd stops working..Take this to service center...
Nov 29, 2008 | Samsung J700 Cellular Phone
Display problem
i also have the same problem...white screen display
May 26, 2008 | Nokia N70 Cellular Phone
White Screen No Work
have the LCD/screen replace...take it to a mobile tech and have that done.
Dec 26, 2007 | Samsung SYNC SGH-A707 Cellular Phone
LG VX5500 Cell Phone Logo
882 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
