Question about Acer Aspire 5670 Notebook
Will not hold settings
I had a crash yesterday, and today everything was gone, except my programs. I redid outlook, and all settings, and 7 hours later, everything is missing again. It seems it will not hold settings. Help???
    Problem Solver:
  • 5 Answers
Battery for cmos maybe. try a restore to your last point unless its too far away in time eithe way i dont know if laptop or desktop but if desktop remove all cards reseat them again go to cmos and set the clock time then watch to see if it changes if so batterry is bad on cmos
Posted on Mar 29, 2008
I cannot get into my computer, that was set up yesterday w/ no problem today its adking for a password for outlook that I have never had, I haveaso.com
Outlook is the default email program.have you tried to configure your emails to go through outlook?you can clear all emails accounts in outlook if you have no need to use outlook to prevent the pop up screen from annoying you.i assume you do have system restore running ...in which case choose a restore date from an earlier time than when the problem started and it should successfully restore settings to work around the issue.acer systems have their own restore capability which you must be careful not to activate or you will lose all your personal files as everything reverts back to factory install.i don't know which operating system you are on so any further advice is limited.
Jun 06, 2015 | Acer Computers & Internet
Dell D 600 purchased yesterday has very small fonts on Outlook Express and websites
"Control +" to make font bigger, "Control -" to make font smaller. I think after doing that, it should be fine, or the resolution needs to be set. Hope helps.
Android 4.0 Tablet PC
Jan 29, 2012 | Dell Latitude D600 Notebook
Hello, I have model 49556/te158wt and I'm not able to set hour ! could you help me ?
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
Link above is the Woods 49555 manual
If the timer will not program, then it has gone bad.
Plug timer into wall receptacle
Back-up battery will charge in about 1-2 hours > if battery will not charge, then timer is no good
Some digital timers require back-up battery to be fully charged before display will show
Back up battery allows programming while timer is removed from receptacle
After timer is programmed, plug timer back into receptacle
Timer buttons show below
To set current time:
Depress RST (Reset) button to clear programs
Press-and-hold TIME button to select 12 hour or 24 hour display
Press-and-hold SET button. Mo Monday will flash in display
Push arrow button until current day shows
Press SET button again. Hours will flash
Press arrow buttons until current hour shows (am or pm)
Push SET button again. Minutes will flash.
Press arrow buttons until current minutes show
Programming ON-OFF
Make a schedule so programs don't conflict
You can set up to 20 on-off programs over 7 days
Each program has ON time Day Hours and Minutes
Each program has OFF time Days Hours and Minutes
Press right-arrow > PROG 1 ON flashes
Press SET > choice of day groupings flash
Press arrow button to select days
Press SET > program1 ON times flash
Press arrows to set ON time
Press SET > program1 for Hour
Repeat sequence described above to set MIN
Repeat sequence to set OFF times for program1
Repeat sequence to set Program2 thru Program20
Press TIME button to finish programming
Oct 12, 2010 | Woods 7 Day Digital Heavy Duty Timer...
Outlook 2007 Crashes
You did the windows 7 upgrade?
if you do a backup and full instal[reformat] it will work,
Apr 15, 2010 | Gateway GT5670 Desktop PC
My outlook and programs seem to freeze as soon as they are opened, or they are extremely slow.I have Windows XP and use a lot of Adobe products such as Photoshop and Illustrator as well as InDesign.
Delete all temp files (c:\windows\temp\*.tmp, or on XP C:\Documents and Settings\username\Local Settings\Temp)
Delete temporary internet files (c:\windows\temporary internet files\*.*, or on XP C:\Documents and Settings\username\Local Settings\Temporary Internet Files) If you use I.E., click on Tools, Internet Options, Delete Files, select "delete all off-line content", click OK
Click on Start, Programs, Accessories, Systems Tools, Disk Cleanup
turn off programs that start automatically in msconfig,then turn them on one at a time after a reboot. Run you system awhile to test. with some patience you will discover what causes your problem.
Jan 03, 2010 | Microsoft Windows XP Professional for PC
My computer crashed, I had it repaired and now I have over 1800 emails. Is there a way I can delete them all at one time?
if your using outlook express or outlook 2003 then yes
click on the 1st message until it highlighted in blue hold down the shift key and goto the last message and while still holding down the **** key click the last message. this will cause them all to be highlighted in blue, now just hit the delete and they shold all be gone
Nov 29, 2008 | Computers & Internet
PlanPlus Constantly Crashes Outlook
this is third party sotware not microsoft. Have you called Franklin Covey?
have you looked to see if you can uninstall this Franklin Covey Plan Plus 5.0 from the add remove programs?
Oct 15, 2008 | Microsoft Office Outlook 2003 for PC
Outlook 2007 slow on closing and crashes on open
Your computer might be using caching. Can you tell me how much RAM you have on your computer? If you have 2GB of RAM i would recommend disabling the caching. This slows down the system quiet a bit (since it uses miliseconds instead of nanoseconds). Your computer is as fast as the slowest component.  I would also suggest defragging the drive.
Oct 14, 2007 | Microsoft Office Professional 2007 Full...
Treo 650 (cingular) and Outlook calendar
Its the substandard conduits that come with the 650. Hi - my issues were different than yours,but similar in that bottom line, my calendar data wasn't syncing correctly with Outlook. I've been dealing with this problem for the past 4 weeks. Sprint's technical support was useless, as was palmone. For 5 years, I have successfully synced my Palm Smart phone to palm desktop at home, and outlook at work - (4 different phones, 4 different companies). It dawned on me - for the past 4 palm devices, I was provided Chapura conduits... The 650 didn't come with them... GUESS WHAT. I bought Chapura Professional XT and all the issues I was having (they were too copious and too weird to go into here) were solved, in one measly synchronization. ALL of them. Don't wast ANY more of your time... Navigate over to Chapura's website and get one of the conduit programs -= trust me... You'll be glad you did.
Sep 11, 2005 | Palm Treo 650 Handheld
T5 synco with Outlook except Tasks
Hard rest resolved problem for me. I just posted yesterday a similar problem with my T3. While everything else was syncing fine, the Tasks from Outlook would not sync. After I posted my question, I (accidently) did a hard reset on my T3. So I set all Outlook conduit settings to 'Desktop overwrite HH' for first hotsync. This somehow corrected the problem with the Tasks, and all outlook tasks appeared on my HH. All sync's seem to be working fine now.
Sep 11, 2005 | Palm Tungsten T5 - Multilingual Handheld
Acer Aspire 5670 Notebook Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
