Question about Sony PlayStation (PS) Console
Crappy PS1 Game
I have a Sony Playstation that works properly. The games work great (most of them are burned on blank discs from different companies)
and so do Music CD's. But there's one bit of a problem, a game called "Megaman Legends" (which is burned on a blank disc) that has a problem. The game works properly at the beginning, but at the point Roll ask's you to come to City Hall after defeating the Marlwolf (which belongs to Teasel Bonne). You have to say yes or no, but after choosing, it will have Megaman reply, then it fades to black. At this point, something should come up, but nothing will come up no matter how long i'll wait! It just stays pitch black! Is it because of the orange paint marker used on the front, because of the scratches on the back, or is it time to get a replacement for the game which is the normal version instead of the burned version? What ever it is, HELP!!!!
  • 1 more comment
  • Anonymous Mar 29, 2008
    Or is it the PS1? It got the PS1 for Xmas a few years ago.
  • Anonymous Apr 01, 2008
    Here's the game for more info (burned on blank disc):
  • Anonymous Apr 12, 2008
    Yeah I was thinking of that.
  • 21 Answers
If it's burned on a blank disk most likely the data is corrupted or the ps1 that you have modded to play blank disks doesen't support a feature in that point of the game. You could try playing the actual game on the intended ps1 format and it should work without any problems.
Posted on Apr 05, 2008
6ya staff
SOURCE:
How to fix rsod on pcsx2 0.9.7
The infamous Red Screen of Desk -- A.K.A. Insert a Format Disc screen.
This screen is NOT asking for a disc to FORMAT the PS2. What it IS asking for is a PS2 or Playstation format [or a better word -- PS2 or Playstation TYPE disc. A disk with Playstation 1 or Playstation 2 type software on it -- in other words, a ps1 or ps2 game]. It's basically asking for a CD or DVD with software that the playstation can play. This red screen occurs when you insert an XBOX game or a burned/copied PS2 or PS1 game. What the PS2 is stating is that is cannot play this format [or type of] disc. It's asking you to insert a format [or type of] disc that it can recognize and use.
The most common reason for this screen appearing, if your PS2 does NOT have a mod chip, is a dirty lens. Try cleaning your lens and this should go away. What happens is that the lens becomes dirty and does not recognize the disc you inserted as being a PS2 or PS1 format [or type of] disc. So it's asking you to insert one. If your PS2 does have a mod chip installed, it could be a problem with the chip or the disc you burned. We don't install or sell mod chips, so we can't help you with that one.
May 20, 2012 | Sony PlayStation 2 (PS2) Console
How to fix rsod in pcsx2 0.9.7
The most common reason for this screen appearing, if your PS2 does NOT have a mod chip, is a dirty lens. Try cleaning your lens and this should go away. What happens is that the lens becomes dirty and does not recognize the disc you inserted as being a PS2 or PS1 format [or type of] disc. So it's asking you to insert one. If your PS2 does have a mod chip installed, it could be a problem with the chip or the disc you burned. I don't install or sell mod chips, so I can't help you with that one...
Getting a disc error when turning on the ps2 with ps2 games, but it works with ps1 games...!
Theres a wheel in the disc drive that controls the elevation of the lens. To mod your ps2 to read burnt ps2 games ONE would alter the height of the lens by adjusting the wheel ever so slightly. There are online tutorials in the precise adjustments for different disks. (one height reads only ps1 games, another height reads ps1 and ps2 games, and one more height reads ps1/ps2 and burnt ps1/ps2 games) Your best bet would probably be to just purchase another ps2 used, but if you want to do it yourself, you can.
Oct 03, 2010 | Sony PlayStation 2 (PS2) Console
Problem with ps1
you will need to get your ps1 chipped if you want to put it on another disc
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
Had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Ps1 games
ps1 game dont work on the ps2 try ps2 games they will work
Oct 09, 2008 | Sony PlayStation 2 Slimline Console
Ps1 games
your slimline might not normally play the games Use swap magic it should have two discs one for booting PS2 games and one for booting PS1 games you simply put the appropriate swap magic disc and then the game you want to play
http://www.swapmagic3.com
This is what it states under What games support Swap Magic 3?
Swap Magic 3 support almost all SEGA ROMS, SNES ROMS, PS1 & PS2 Games!!
Feb 23, 2008 | Sony PlayStation 2 Slimline Console
Playstation card
Your question is somewhat confusing, using a playstation 2 memory card, will have PS2 game saves on it, how would you play PS2 games on a PS1 from the save, you can't. If you just mean you are using a PS2 card for a PS1, the way a PS2 card saves data is different to a PS1 card, so it probably won't work You can use your PS1 memory cards in the PS2. You can only use the PS1 memory cards to save PS1 games that you are playing in your PS2. You can't save any PS2 game data to a PS1 memory card
Oct 05, 2007 | Sony PlayStation (PS) Console
Sony PlayStation (PS) Console Logo
71 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
