Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
Wiring diagram for Dyson DC05 Motor. Bought a replacement motor and wiring slightly different from original. Thermal cutout on both motors.
2 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: dyson dc05 motor cuts out
Check for either voltage to switch or if your not happy or compettant working on live mains.
Switch meter to ohms ensure vacuum is unpluged from mains follow live wire (brown) from plug to exit point on the back of cable rewinder check for continuity shold be dead short if it is check switch if this is ok move to neutral (blue) wire again check from plug to rear of cable winder.
The neutral then goes off to moter again check for dead short,
I think from experience that you will have A break in either live or neutral in the mains lead going to cable winder.
If it is its realy easy to replace winder they come with lead all ready fitted.
If you need one contact me.
http://dysonmanuals.llc.nu/index.htm
Chris...
Posted on Dec 07, 2008
Dyson dc05 power head not working. Fitted new hose and power head
please go to http://www.dyson.com/support/help.asp?article=32&product=DC22-MOTORHEAD-US
please select the model exactly, and proceed with common sense for troubleshooting problem and fix it.
You must shure to see the videos, and see if the parts installed is o.k or are not. You must test the belt is broken, worn, or bad installed. test the motor for brush, bearing and lubrication, and finllay the thermal fuse inside or thermal switch.
God bless you
Jul 15, 2012 | Dyson DC05 Cylinder Bagless Canister...
Dyson DC05 MotorHead schematic
Hi David,
Unfortunately the DC05's Motorhead is supplied as a complete assembly, so we're unable to offer individual components to repair your Motorhead. If you'd like to order a replacement Motorhead assembly, you can do so via our Helpline on 0800 298 0298, or through our online store:
http://www.dyson.co.uk/Spares/Variant-Spares.aspx?pid=DC05-Motorhead
Best wishes,
Jack
Dyson Online Customer Support
Apr 13, 2012 | Dyson DC05 Bagless Canister Cyclonic...
I have a dyson dc05 absolute turbobrush vacuum. turned it on and it slowly died in seconds. then tried to turn on again and only came on sporatically for a moment. Is it the on/off switch or motor?
Hi there VacuumGuru for vacuumspot.com.au here. It is likely to be the motor for that model but it is easy to test. I will answer this with the assumption that a person wouldn't try to repair something they are not qualified to do. All you have to do is disconnect the wires off your switch and join them together (with power cord disconnected from socket obviously). Then plug you cord in again. If it still plays up then it is your motor if its fine replace your switch. We stock switches and the motor for that machine if you live in australia by the way.
Vacuumspot.com.au
Hope this helps.
Oct 14, 2010 | Dyson DC05 Bagless Canister Cyclonic...
I changed the motor in my Dyson Animal hoover and works fine but after 15 minutes it stops as if it was turned off, if i leave it for a period (2 hrs)it will start up again and work for a further 15 mins...
Hi there
All Dyson vacuum cleaners are fitted with a thermal cutout, which will switch off the motor if it becomes too hot. This is normally caused by a lack of airflow to the motor, i.e caused by a blockage or a dirty filter.
I would make sure that you have completed the full blockage procedure and have thoroughly washed the filter and see if this helps.
Kind regards
Darran
Dyson Customer Service
Apr 19, 2010 | Dyson DC05 Cylinder Bagless Canister...
My dyson dc05 just stopped working,any idea what the fault could be? i,ve had it about 7 years
Guessing that the power plug has broken wiring inside the plug--try replacing the plug with an aftermarket plug from the home center or hardware store. Another possibility is the power switch has gone bad--replace it with the proper part ordered from an appliance parts store. Another part that can go bad is the motor brushes, but that requires that the vacuum be fairly well disassembled. Good luck!
Apr 11, 2010 | Dyson DC05 Bagless Canister Cyclonic...
Dyson dc05 motor cuts out
Chris...
Nov 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson
Hi.
Check mains lead where it enters machine very common for internal fracture.
To prove this try waggling lead with machine switched on if it starts & stops this is the fault.
http://dc07.atspace.com/
Chris..
Dec 23, 2007 | Dyson DC05 Cylinder Bagless Canister...
DYSON DC05
My friends Dyson DC05 was loosing suction and then it stopped altogether one day. When she took the filters out there was black soot in them so it was obvious that the motor had burnt out. I think this happened because she wasn't cleaning the filters regularly (go do yours now!) I replaced the motor myself and wrote a guide with photo's at www.tasweb.org
Dec 11, 2007 | Dyson DC05 Cylinder Bagless Canister...
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
446 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
