Question about Yamaha HTR-5760 Receiver
Setting up the htr-570 with BrightHouse DRV and Sony HiDef TV
Brighthouse remote code for lg 32 inch led tv
Here is a brighthouse code sheet for lg if you can read it. http://support.brighthouse.com/media/video/equipment/remotes/Remotes%20II/UR5.pdf
They make different remotes if this link does not help please provide which brighthouse remote you have.
Nov 28, 2015 | LG Televison & Video
I have a hisense 50H5G and i cant figure why it wont go to 1080. Its says 480 and i have a hdmi cable and hidef channels. Please help
Try to change from your HIDEF output setting from 480 to 1080 if output from HIDEF not proper then your TV also not work at 1080
Jan 25, 2015 | Hisense Televison & Video
We can't program the tv with the brighthouse cable
This is a brighthouse problem not a TV problem, if brighthouse won't help you just use the original or substitue remote.
The brighthouse remote may locate the correct frequency using the scan method ask them to send a remote book.
Thanks
Roety
Nov 30, 2009 | Televison & Video
We have a Panasonic 1080P Plasma TV hooked up to BrightHouse Cable and a Blue Ray player. We use a Brighthouse remove to control all. We are trying to hook up a Panasonic DMR-E80H DVD Recorder. We are...
If your tv has inputs for many devices you can connect them. You need to simply change the tv input SOURCE to whatever #/type of input you want to view from.
You can use an y remote if programmed properly- that is another issue. programming the remote to control that deviovce but first see if it works right.
if the brighthouse remote can control the tv, change the input or source to whatever the dvd is in, other wise try the tv remote.
make it simple first, then you can try getting the one remote to control it IF it can.
my cable remote cannot control all my devices but does the tv.
Mar 25, 2017 | Panasonic Televison & Video
Record hidef films to media without computer
You should first ensure that the TV support video and audio OUT!
This will determine what connectors yo have available. Most connections will be for video and audio IN. You may have one connector for video/audio out which you can use. Chances are this will NOT be HiDef.
Nov 05, 2009 | Computers & Internet
No HiDef on projection TV
u need a hd receiver to get hd on this tv. satellite or cable box. the screen blank in and out on hd signal. get use to the blackout.
Nov 15, 2008 | Hitachi 43FDX01B TV
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha HTR-5760 Receiver Logo
115 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
