Monitor audio problems
Hardrive was wiped, no sound card driver either
  • 2 more comments
  • bfarrington2 Mar 29, 2008
    I apologize, it had XP before it was wiped, I installed 2000pro. So far everything is working fine. I have video, just no audio through the monitor speakers. When I checked the device manager it said i have no audio driver. I tried downloading a sound card, but the installation wizard comes up with portcls.sys disk #4 needed. I don't have that disk because i bought the sys. used.
    Hope this helps
    I apologize, It had XP before it was wiped. I installed 2000pro. So far everything works fine, I have video just no audio from the monitor speakers. I checked the device manager and it says i have no audio driver. I tried to download an audio driver but a window pops up saying portcls.sys disk#4 needed. I don't have any disks for this comp. because I bought it used.
    Hope this helps
  • Anonymous Dec 07, 2008
    how i do download portcls.sys
  • Clifford Hardy
    Clifford Hardy May 11, 2010
    do you have an oprating system on the computer
  • 111 Answers
Install windows xp
Posted on Mar 29, 2008
SOURCE:
How can I download free audio driver for microtek c593? Please help me, thanks.
Monitor does not need sound driver, just think of it as nothing more than powered PC speakers mounted inside monitor case. You need correct sound card driver in the PC to get sound.
Testing monitor speakers: use an MP3 player to feed to monitor audio line input (Green jack) using audio cable with mini stereo male phone jack at both ends (try Radio Shack) , set the volume on the monitor half way. If you get the sound OK, then the problem is in the PC setup.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 28, 2010 | Microtek C593 15" Flat Panel LCD Monitor
Can't hear volume from my monitor
We need to find out if the problem is in the monitor or at the PC sound card. Try feeding the monitor with sound sound source such as MP3 player to the audio line in of the monitor to see if you get the sound or not. If you do not, then you will need to open up the monitor and inspect the audio power amplifier circuits. If you get the sound OK, then verify that the cable between the PC audio line out (green jack) and the monitor audio input (green jack), next verify that the audio level controls (on screen volume control panel) are set up OK, not at minimum setting. Verify that correct driver for the sound card is installed.
Apr 29, 2010 | Hannspree HW191D LCD Monitor
Need the sound drivers for the monitor
You do not need sound driver for the monitor, but you do need the sound card driver for your sound card. Your monitor has powered speakers built-in, you just need to connect the green mini stereo jack from sound card audio out to monitor audio line in and adjust the volume control at both monitor and the PC.
Nov 30, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
My (M-AUDIO FW 410)drivers had suddenly got kicked off. (i honestly don't know what had happend to my drivers) So i went on line to get the latest drivers for my (MAC BOOK PRO/10.4.11).... It didn't work....
Unfortunately, you may have to upgrade. Depending how old your system is typically you need to upgrade every 3 to 4 years. You might upgrade your RAM. When you turn on your computer wait at least 5 minutes for all your drivers to load. If you open up an application before they load it may cause a conflict and not load all drivers. Make sure your not connected to the Internet. When your connected to the Internet all your programs that are not set up to not look for updates will. You wont even know that their doing this until it's to late. This is what I would do. Go to your system restore and restore to a point that you knew it was working. When you look at your restore options it will give you a list by day what was added. Just look at these day's and try and remember what you installed before this started happening. You're having a conflicting problem. Now we need to find out where. Feel free to contact me with any other questions. Hope this helps.
JimmyC
Sep 25, 2009 | M-Audio FireWire 410 External Sound System
I have recently had a new hardrive put in my compaq v6000 and my laptop will not play any sound
Dear you are fishing a problem with sound whit-out change any type of hardware just parches
USB TO SOUND CARD OK just install in use port and after install driver and working ................ok
save money and time ok...........both of important
Jan 31, 2009 | Compaq 113897-002 - PCI Sound card
Sound card on legacy drivers
Hi
You Have Mother Board Drivers cd. Plz insert IN cd rom Drive your MBD cd go to Audio Driver's select Windows XP folder Next go to Setup.exe click Dubul from setup complete Install That Drivers reboot your system after that sound as com in your sys
ok if any probalm see www.soundrivers.com ok by
Apr 17, 2008 | Creative Labs Sound Blaster Live! 5.1...
Sound driver
check the model of your foxconn motherboard and check foxconn site for downloads, it should help
Apr 07, 2008 | Computers & Internet
No audio from monitor
you don`t need a driver for the monitor sounds like the sound card driver
Mar 29, 2008 | Audio Players & Recorders
No sound out of monitor speakers
Is there actually any unknown devices in the device`manager?
Are your monitor speakers USB or do they plug into the audio out jack of your sound card or motherboard???
If they plug into the sound jack, then test the sound output with a pair of headphones.
Hope this helps you narrow it down. Please reply back if you need further help
Dec 30, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Sound
In Windows XP Select the proper Audio Input Device (Sound Recording) under the Audio Tab in Sounds and Audio Devices in Control panel. Usually it is name after the USB Camera. Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 15, 2007 | Logitech QuickCam 961464-0403 Webcam
42 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
