Question about Sirius Satellite Radio Receiver
My fuse blows everytime i plug in my sirius radio to cigarette lighter...why?
  • 161 Answers
Is that the only device that is blowing a fuse? if it is the only thing blowing your fuse you may need to replace the charger. check the fuse to make sure it is the correct size ( usually 10 amp). check the power adapter to make sure there are no loose connections or anything in the plug that doesn't belong there. unplug the radio from the adapter and plug the adapter in without the radio see if the fuse blows . if it blows replace the adapter. if it doesn't blow the fuse check the adapter to make sure it is the right one make sure the polarity is correct
Posted on May 12, 2010
EVERYTIME I HOOK UP MY CB IT BLOWS A FUSE -- ANYONE KNOW WHY ?
Could be a bad ground, or you could be plugging into a circuit that already had to much on it. Typically you want to plug a cb into something like your cigarette lighter circuit.
Mar 01, 2013 | Radio Communications
Radio stopped working when we hit a bump in the road, we did get it back on but now the fuse number 4 for the cigarette lighter and mirror won't stay on, it keeps blowing everytime we plug something into...
Hi sounds like you have a dodgy power wire thats making contact causing fuse to blow, i would start by checking everthing on that circuit with the radio being first as that would be the most common cause
Mar 27, 2011 | 2004 Subaru Outback
I have a 2000 gmc yukon denali and everytime i push my ciggarete lighter in it blows the fuse and my radio also stops working
Replace the cigarette lighter. Parts houses have the right one for your Yukon.
The lighter itself shorts out so when you push it in it creates an immediate dead short . Fuse Blows.
Thanks for using Fix Ya.
Wayne
Mar 18, 2011 | GMC Yukon Denali Cars & Trucks
I just got my first cb and am trying to install it. I have connected the red wire in the fuse box( to the radio) and grounded the black wire. turned the car on and I cannot get any power to the CB, but the...
Take a deep breath and start over! The best way to power this little radio is probably through the cigarette lighter or 12vdc accessory jack. It is simple and straight forward and no fuse box or negative ground wires to worry about. Go the Radio Shack, purchase an adaptor (cig lighter type) and hook it up to your radio wiring being careful to watch polarity. You may have to have your ignition on to run the radio, but that is much safer that maybe blowing up the unit.
Unless you are running a larger more powerful unit or an amp, there is no added benefit to hooking the radio into the fuse box.
Dec 16, 2010 | Cobra 19 DX IV CB Radio
Can't found a blow fuse on a audiovox sirus sat
TWIST OPEN THE END OF THE CIGARETTE LIGHTER ADAPTER AND YOU'LL FIND A GLASS FUSE IN IT.
BE CAREFUL THERE MIGHT BE A SPRING IN IT THAT HOLDS FUSE DONT LOOSE IT.
Oct 20, 2009 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Radio fuse keeps blowing
make sure nothing in cig lighter socket..coins,etc..if nothing present,unplug cig lighter socket and replace fuse..if fuse doesn't blow,it's the socket causing fault..if it does,unplug radio,plug cig lighter back in and replace fuse..if fuse doesn't blow,radio is cause of fault..if it does,then ther is short in wiring
May 19, 2009 | 1992 Honda Accord
2004 Dodge 1500 blowing fuses
Replace the cigarette lighter. Look to find out what else is on the instument cluster circuit, as that may be the problem, or a bad cluster.
Mar 07, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Cigarette lighters
check the fuse for dome and the map light if applicable
Jul 04, 2008 | 2004 Oldsmobile Alero
Sirius Satellite Radio Receiver Logo
923 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
