Question about Century Portable Plasma Cutter 82021
Century mig wire fed welder model 117-076 125 gs it welds but seems to not b getting hot enough will weld very small stuff but still not hot enough can u help me
  • 12,061 Answers
Http://www.weldingtipsandtricks.com/Mig-welding-tips.html
http://igor.chudov.com/manuals/MX001.pdf
http://www.letstalksnow.com/forums/archive/index.php/t-15449.html
Your unit has severe limitations, "It will not weld 1/4" single pass" (sic) . apparently, check out the Forum above, Also you need to ensure everything is "Just So" as when of limited power as this is, the GROUND or earth must be REALLY GOOD CONNECTION, the INPUT mains supply must be good, and correct wire size used too. http://www.weldingtipsandtricks.com/lincoln-mig-welder.html
Please visit all the links, and read how to make it work better.
Posted on May 12, 2010
  • junkman2542 May 12, 2010
    its like when i say its welding i mean like you might b able to tack something but not to good at all i mean we have checked the power and everything its not the first welder i have used i think theres a problem internally is what im asking
My welder won't feed wire it sounds like it's trying to energize but can't. A couple of times it fed through but wouldn't feed to weld so I had stick weld. What happens if the liner has a restriction?
first unscrew the tiny tip at very end of torch (can be hot)!! then try to feed wire thru handle,gently shake cable as you do helps to feed wire thru cable , if successful you have allowed the amps to get too high for the feed rate (slow) and melted the tip closed , these tips are replaceable from miller and are not expensive
Aug 09, 2016 | Miller Multimatic 200 MIG TIG & Stick...
Welding will not hold
turn your heat wire speed up hope for the best too small of a machine
Oct 13, 2012 | Lincoln Electric Welding Tools
Will a ya219b snap on by century mig welder weld flux core wire
Are you using knurled rollers? Check the wire. Is it reversed polarity. Flux cored wire is very voltage sensitive.
Jun 14, 2012 | Century Welding Tools
I have a 250 bobcat that stick welds just fine but when you go to wire feed and plug in suitcase box wire feed unit wire feeds but it doesn't get hot enough to melt the wire. LF299725
What model of suitcase? Could be the contactor in the suitcase, could be the mig gun. Are you using the CV setting on the Bobcat, instead of CC? Is the Bobcat on the high CV setting and the dial most of the way?
Apr 30, 2012 | Miller Bobcat 3 Phase Welder Generator...
My welder no longer produces high quality welds
You could have a poor ground clamp connection. Check that. also increasing the gas flow will cause turbulence at the weld, this can have a negative effect on weld quality.
Check your connections, check your liner, actually, replace it if you haven't recently.
Feb 15, 2010 | Lincoln Electric LE 83180 Century...
Mig Question
MIG stands for Metal Inert Gas welding, many times called Wire-feed.. Also referred as GMAW (Gas Metal Arc Welding). The "Metal" refers to the wire which is what is used to start the arc. It is shielded by inert gas and the feeding wire also acts as the filler rod. A semi-automatic process, it is fairly easy to learn and use.
Aug 27, 2008 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Mig problem
For certain type of work TIG is required, like welding chrome moly for some racing organizations. Intricate work, like gunsmithing is also well suited to TIG. TIG is used by many auto restorers who prefer a more precise, perfect finish that requires little to no finish work. TIG is most similar to gas welding in technique, so if you've done oxy-fuel welding, TIG should be a natural transition. MIG is required by law and by insurance companies in many localities for structural repair of automotive frames. MIG is also much easier to learn and faster to weld. For doing other types of welding, like sheet metal, it can be a matter of personal preference. For an auto body repair shop or a novice welder, a MIG is a good, practical all-around welder.
Aug 27, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
Century Portable Plasma Cutter 82021 Logo
1,580 people viewed this question
Top Century Welding Tools Experts
John Trevino
Ted Maxwell
Tom Chichester
Are you a Century Welding Tool Expert? Answer questions, earn points and help others
