RICOH 1224C COPIES ARE SMEARED
IT COPIES FINE BUT 2 OUT OF 3 COPIES ARE SMEARED ON THE RIGHT SIDE OF THE PAGE...WHAT COULD IT BE?
    Guru:
  • 1,049 Answers
Smeared output can also result when you refeed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
If this does not resolve your issue then make sure the fuser is heating; if not, the thermostat is bad and you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
Posted on May 12, 2010
Black image streaks on sharp 2700n
You only have to make single color copies with each color CMYK
and check all the copies if only the black and white copies is smeary
then replace only the black the drum unit.
Mar 21, 2014 | Sharp MX-2700N Color Copier
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
The printer works fine. Scans and copies streaky.
I have the same printer, Its just needs cleaning. Go to problem solver inside menu and follow the instructions
Jul 26, 2010 | Epson WorkForce 600 All-In-One InkJet...
Blurred section on copies.
When looking at your copy is the 1/3rd that is blurry at the top of the page with the bottom 2/3rd's being fine? Or is the 1/3rd that is bad go up and down the right or left side? I am trying to determine if the defect runs up and down the pade as you look at the copy or is it "across" the top or bottom of the page.
Dec 22, 2009 | Office Equipment & Supplies
Smeared print on paper
I was getting a similar blur/blob down one side of the paper (with no discernable print anywhere,) but after removing and emptying the toner collection bottle my printing returned to normal. I am still working on the size mismatch issue, which seems to be prevalent in the 2300DL population.
Aug 25, 2009 | Office Equipment & Supplies
Copies are coming out in various shades of black - like its smeared...
Most common cause is a dirty corona wire and or drum. If after cleaning the corona wire and drum the copies are still mostly black and smeared, the drum may be broken. Best of luck.
Greg
Jul 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Copies coming out almost blacked out
Hello sir; Try to make a copy with cover open, then you can see the lamp is on or not, if not then check the thermos fuse at the ned of exposure lamp or exposure lamp, otherwise you ha go to check the drum blade isn't under good condition if everythingare good final you have to replace developer.
May 29, 2009 | Toshiba e-Studio 350 Copier
Same black line on right side problem
take out your drum unit and make the blue plastic corona wire cleaner on the drum unit is pushed all the way over to right side. see if that helps.
razors
Dec 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Minolta cf900 maintenance tips
Dear Laker31,
you can find the right Tips ,on this Site:
http://solutions.konicaminolta.com.au/intranet/tsg/training/msds.cfm?b=CF900
Cheerup and Be Happy Always
Mar 14, 2008 | Computers & Internet
135 people viewed this question
jasbo
jasbo
