Question about Kitchen Appliances - Others
I need to replace my Betty Crocker stove-top whistling tea-kettle as I inadvertently turned on the element under it when it contained no water and burned it. I've looked everywhere but can't find the double-handled model I have. Has it been discontinued? The handle is a loop within the a loop and is very elegant. If I have to I'll purchase the identical model (but with only one looped handle) at Canadian Tire. Thankss, Lisa
  • 4102 Answers
SOURCE: sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Posted on Nov 17, 2007
chie-chie
  • 98 Answers
SOURCE: brewing loose leaf
yes
Posted on Feb 06, 2008
SOURCE: Boiling
Purchased at Canadian Tire mid December 07.....great sale....still more than I expected to spend on a kettle. EE and nothing.....same as previous customer comments.
Posted on Feb 28, 2008
  • 70 Answers
SOURCE: The tea kettle stopped whistling...
I could be that you have some debris in the hole. Try running a pipe cleaner though it a few times and see if it helps.
Posted on Mar 18, 2009
  • 3 Answers
SOURCE: Red light's on... but no hot water!
Just a bit of clarification; the lights and heating element are both downstream of the thermal protection ( I had mine apart and had a look). Therefore the lights would be off if the thermal protection had kicked in.
Lights on but no heat means element has a problem. Could be loose wire but more likely burnt out. If you have a tamper proof TORX bit you can take the bottom cover off and check for continuity through the element. Isolate the lights from the element so your meter is not accidentally seeing continuity through the lights.
Posted on Apr 12, 2009
Replacement blade for Betty Croker Blender BCF1350
Since Betty Crocker makes no machines or tools, but contracts with companies to make them, first find out who made this one.
Then go online and look for parts.
God bless your efforts.
Sep 06, 2015 | Betty Crocker Blenders
Help! Do you have a replacement jar for a Betty Crocker Blender Model: BCF1350?
Fixya does not sell replacement jars. Check with a local appliance parts supplier.
Aug 12, 2014 | Betty Crocker BCF1350 Work Top Blender
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
Popcorn maker bc-2970cr not heating
Check the overheat sensor is working. Then check the heating element of the kettle. Or may rusted surface on the connecting terminals.
Mar 14, 2014 | Kitchen Appliances - Others
I have a betty crocker iced tea maker model # bc1781 and i do not remember how to use it please assist
mcdevito75 here, Check online at Betty Crocker Iced tea maker., Get model number off the maker itself.
Jun 20, 2010 | Coffee Makers & Espresso Machines
Can't find replacement for glass top of Betty Crocker Blender BR - 301. I live in Halifax, Nova Scotia, Canada.
I bought a Betty Crocker blender at an auction and they put the wrong top with it. Where can I find the correct top for the Model # BC-1352 blendor.
Feb 09, 2010 | Betty Crocker Blenders
Will not whistle
It is possible the reed valve broke.
Aug 02, 2009 | Electrolux CHANTAL Loop Tea Kettle -...
We need the recipes for the 1691 Betty Crocker breadmaker.
There's an original copy of the manual which usually contains a few sample recipes for sale on eBay right now. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370110114738
Jan 25, 2009 | Betty Crocker BCF1690 Bread Maker
Code reading
replace the serp belt and check idler and tentioner pullys. serp belts make noise after antifreeze or oil has been on them. good luck
Jun 23, 2008 | 1995 Chevrolet Tahoe
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Nov 06, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
70 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
