Question about Lanier Office Equipment & Supplies
Lanier 6713 cleaning
Our Lanier 6713 copier was dropped on the floor a few years ago...cracked the glass plate in the corner, but still works. However, there is toner everywhere inside of it. I'm not sure where to start to clean it, and can't even find the user manual. Obviously our copy quality is getting worse-very dark.
What can I do to improve things to get us by until we get a new copier? I've read not to use a regular vacuum cleaner because of the charged toner particles, and I can't even tell what is the drum because of the coating of toner on everything.
All Office
  • 58 Answers
SOURCE: Dark Copies
Jim, A couple of things: 1. OEM (Canon original) toner cartridge or remanufactured/compatible? The first place to start is always with the toner cartridge when image problems occur. Pull the cartridge out and draw back the drum cover. Check to see if the drum is a nice "clean" blue color or if the lines and spots are on it like you described. (These two areas should be handled by someone with experience in copy service) 2. The next thing would involved cleaning under the copy glass. Build up from dust, etc causes a "fogginess" that makes the machine try to adjust the intensity of the exposure lamp to conpensate for this. 3. Also could be a bad upper fuser roller if you started having any paper jams when to paper exits.
Posted on Jul 19, 2007
  • 62 Answers
SOURCE: Canon NP 6030 dark copies
Have you cleaned the slit-glass located behind the drum? Its a thin piece of glass that is about the length of a drum assembly. Check that the drum voltages on the drum label have been correctly installed. Perform a AVPC in service mode to set the primary charge value.
Posted on Oct 24, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Brother MFC-8500 prints solid gray pages
I have seen the Toner cartridge in these cause this and also thought it was drum but new toner actually fixes it, have you installed new gen toner as well as drum? Make sure you tell machine you have fitted new drum too,
Posted on Oct 27, 2007
  • 53 Answers
SOURCE: xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Posted on Feb 27, 2008
SOURCE: I have a lanier 6713 that streaks and makes dirty
Cleaned the optics yet?
Are the drum and blade ok?
Maybe Fuser?
Posted on Feb 27, 2009
How to clean between glass on whirlpool oven door
Ya gotta take the door off the stove and remove the base plate then get the glass out and clean it; a few years ago I replaced a handle on a oven door and here is how I did it:
Aug 08, 2016 | Whirlpool Ovens
Why am I getting lines on my prints when I go thru the top feed of my Lanier LD425C?
Clean the **** glass. It is a long skinny glass to the left of the big rectangular glass under the feeder. Clean it and your problem should go away.
Aug 30, 2012 | Lanier Office Equipment & Supplies
We have a Lanier 5618 copier. Toner must have spilled out and the copies are coming our covered with thick black lines on the entire page. How do we open the machine to clean it?
first you have to see if it happens when they get to a copy or a print. If it happens in print there is not much to clean, you have to replace worn parts. If it happens only on the copy you have mirrors Sanner dirty. (strip the screws and lifting the glass carefully cleaned the mirrors).
Hope this has helped
Jan 20, 2011 | Lanier Office Equipment & Supplies
I need to purchase a 802.11b Interface Card for Lanier 5645. Do you know where I can find one?
contact your local lanier dealer and tell them what you need. beware though the 5645 is a few years old, it may not be available
Oct 12, 2009 | Lanier Office Equipment & Supplies
Error SC101 on copier
No, you can't reset. You'll need a tech. Here's what the manual says: Symptom (SC101) - Exposure lamp error - The standard white level was not detected properly when scanning the white plate. Possible Cause: ? Exposure lamp defective ? Lamp stabilizer defective ? Exposure lamp connector defective ? Standard white plate dirty ? Scanner mirror or scanner lens out of position or dirty ? SBU defective
Jun 10, 2009 | Lanier Office Equipment & Supplies
Dark copies with overprinting
Cleaned the coronas as per instruction book. Done this before but this time it made a difference.
May 07, 2009 | Lanier 1205 Copier
Cracked camera lens on my Motorola Razr
you just need to replace the housing of the phone to correct this issue.
Oct 24, 2008 | Motorola Mobility RAZR V3
Error code Sc101
SC101 can be caused by a dirty WHITE LEADING EDGE STRIP. This is located under the left side plastic strip that holds down the exposure glass on the left side. Remove the screws, and flip over the glass holder. Clean the white strip with glass cleaner, and reassemble. If SC101 reappears, the scanner drive pulley screws are loose or broken off. A service technician is required for this repair.
Feb 20, 2008 | Lanier 1205 Copier
Can't Print on Card
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
141 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
