Question about Tascam 2488 Portastudio Multitrack Recorder System
Mic/line inputs Yamaha md8 Multitrack recorder not working
(not a tascam)
I have a Yamaha md8 Multitrack recorder and the phantom powered mic inputs (1+2) are not working - the normal 1/4" jack inputs are working fine but the mic/line inputs which are phantom powered are not. Can you tell me how to fix this?
I have looked for a service manual /circuit diagram but cannot find one.
Can you help?
Thanks
Ljinno
  • 4,234 Answers
A little testing is required to nail this down.
1) Will a standard mic work in either channel?
2) Will a line level source work in either channel?
It is likely that either the power supply for the phantom power or the supply for the mic pre-amp IC has failed or the IC itself has failed. If a standard mic works, then it is the phantom power supply that is faulty.
I am not aware of any service manual available other than from Yamaha directly (for a price of course...)
If you can update this with the test results, perhaps we can walk through this repair.
Dan
Posted on May 12, 2010
How can I switch the mic input from the built-in mics to XLR input?
on the left side of the unit there is a small switch , , set this switch to MIc , or if using a condenser mic set to phantom-mic this gives the mic power , but I will caution you to watch you units power ind as with that setting you battery will drain down quicker than usuall , you will get best results with balanced mic's as the other types will introduce noise (thumping sound) into the recording also try to keep cord lengths down to less than 15 feet as this will introduce noise into recording as well
Mar 17, 2016 | Tascam DR-40 Portable Digital Recorder
No sound from mxl 990 condenser mic
From the Micropower PS400 product description it states:
"routes the microphone signal to a mixer or a microphone preamplifier."
• these is just a phantom power supply.
One reason your former setup is OK , is that
tascam m-50 is a mixer preamplifier.
• phantom power supply is just a part of the mic preamp of the mixer
to power up your mxl 990 condenser mic
• What you may need is something like these:
X2u XLR to USB Signal Adapter
Sep 29, 2012 | MXL 990 Professional Microphone
I have followed the directions (the manuel and even youtube videos) about 5 times already, but I am not getting any reading from my mic. I have the US-144 and a mac. I talk into the mic, but it's not...
What model is your mic? Some mic's need the phantom power switch turned on. I have the US-144u and it works great with my RODE NT1-A both on MAC and PC. What software are you using to record with?
If you mic is not using the XLR type connection, you will have to set the switch to Guitar / Line In not Mic
Chris
Aug 10, 2011 | Tascam US-144 Sound Card
Getting mic setup thru cubase le 4
Make sure phantom power is enabled on the Tascam audio interface and you must enable the input in cubase that corresponds with the interface input on the track you are trying to record to.
Sep 28, 2009 | Tascam US-144 Sound Card
I just received my Tascam 2488 Neo recorder. I did not get the mic to work. I pluged it in to the back, but I am not sure if the phantom power is on or off when the button is down??
When the button is down phantom power is on (for the first four inputs only... A to D... which are XLR or 1/4" ... the others don't have phantom power).
Make sure that the trim pot for the input is turned up. You should see the meters moving for the stereo bus in the LCD screen when using the mic even if the input isn't yet assigned to a track (and hear it assuming your monitors or stereo system is set up already and the master fader is turned up).
Jan 13, 2009 | Tascam 2488 Portastudio Multitrack...
Need to know how to use mic with dp-01
First you'll need to know if your mic is dynamic or requires phantom power. The DP-01 does not provide phantom power, but the DP-01FX and the DP01-FX/CD units have the option of turning on phantom power for their two XRL mic jacks. The DP-01 simply has 1/4" jacks for mics. Typically if your mic comes with a 1/4" plug it will be dynamic, but that isn't always true.
Plug it into the mic/line jack in the front of the unit and turn up the input volume knob. Then depending on which of the two inputs you used you'll have to press the Assign button (A or B) and then the rec button over one of the tracks and turn up the track fader. You'll also need to insure that the master fader is turned up and you should then be able to see the meters moving when speaking into the mic and hear the output in your headphones.
To record simply press the rec button on the assigned track again (it will light steady) to arm the track for recording and press the play and record together.
Hope this helps.
bd.
Jan 08, 2009 | Tascam DP01 All-In-One Recording Package...
Tascam 2488
You'd plug the XLR connection into any of the first four inputs on the 2488 (labelled a to d). This is a dynamic mic so you don't need phantom power and should make sure your phantom power switch is off (out) on the 2488. You'd then assign the input you've chosen to a track, arm the track for recording, turn up the input level for that input to test the signal level, and record away by pressing record and play together.
Hope this helps.
bd.
Nov 02, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
I've just got a tascam dp01cf recorder and i'm having trouble with it, its abit hard to understand what to plugs in were, i'm using a electric guitar,a yamaha magicstomp effect pedal and a amp. also i'm...
You have a couple of options with your guitar input. You can either plug your guitar directly into the right (Hi-Z) input and use the Tascam's onboard effects with it instead of your effect pedal.
You can put your pedal in the chain between your guitar and the (Hi-Z) input. So guitar into pedal is, pedal out into Tascam Hi-z in. (Still doesn't use the amp).
Or my preferred method for recording guitar would be to mic the amp. In that case you'd just input a microphone (placed about 8-12 inches from your amp) and record your guitar that way. The mic would be plugged into either one of the Tascams two mic inputs to record the amps speaker output while your guitar, pedal and amp would just be hooked up in the normal way.
Please note: Never plug the output from an amp into any of the Tascams inputs. Those inputs are line-level and the speaker output level which comes out of an amp out would damage your Tascam.
To get a backing song into a track in your Tascam, you'll have to first, using a PC, get the song into a 16 bit mono Wav file format. Then you'll have to use the USB import function to copy that wav file onto your Tascam onto the CF media cards fat partition. From the you'll be able to import it into the Tascam choosing which track it will import into.
Cheers,
BD
Apr 17, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam us 144
Stereo requires two different inputs, as the very name implies. If you're using just one mic, it is possible to "pan" that input to both left and right, but is not truly stereo. For true stereo, you must have at least 2 mics, or 2 or more of any other sources...accordianman
Feb 22, 2008 | Tascam US-144 Sound Card
Tascam 2488 Portastudio Multitrack Recorder System Logo
337 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
