Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
GOOD DAY . I HAVE THE TOSHIBA 52-HMA DLP TELEVISON AND I WAS WONDERING HOW TO INSTALL A BALLAST.
  • timothy91234 May 13, 2010
    good day i'm still trying to get information on how to install the ballast on toshiba model 52hm84
  • 2,335 Answers
I can help you install your Toshiba 52-HM84 52" DLP HDTV ballast.
Please download and refer to the instructions for ballast replacement on page 17 of the Toshiba 52-HM84 52" DLP HDTV Service Manual.
I hope that helps.
____________________________________________
Posted on May 13, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please follow the step by step procedure and pictures on the link---
How to replace Ballast of Toshiba TV
But read the warning given in red. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional as the TV components contains high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 12, 2010
  • Rylee Smith
    Rylee Smith May 13, 2010
    Hi Tim,
    Thanks
    Rylee
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
I have a toshiba 46hm94p dlp tv. i need to replace the ballast. i pulled the tv apart and got the part number off the ballast, it is RPB-4434ZA . when i look that up by the part number it says its the...
yes they both the same part number one is board number and other is manufacturer number, board number is what it is and manufacture number is if its in other tvs.
Jul 15, 2017 | Toshiba TheaterWide 46HM94 46" Rear...
52HM84 Toshiba DLP with apparent failed lamp (replaced ballast)
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
Jan 18, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
No sound no picture and new bulb red and green flashing lights on power up.....
The problem is either the lamp ballast or the light engine. My guess is the ballast. Part cost ranges between about $75 to $150 depending where you get it. If you're handy you can replace it yourself. I posted the process elsewhere on this site for another Toshiba DLP question (I think it was for a 46HM84). Good Luck.
Jun 21, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
46hm84 toshiba problem
You will find that when the old lamp exploded, either it damaged the ballast unit or there are shards of glass stopping the cooling fan.
May 04, 2017 | Toshiba 46H84 46" Rear Projection...
Toshiba 52HM84 Ballast replacement help
It is very easy to fix/reolace the ballast in these sets. I just fixed the ballast in mine yesturday,by replacing a single resistor on the ballast board (the resistor is labled R3 on the ballast), Google "Toshiba ballast replacement" and there is a nice write up with pictures to guide you through it. If you can soulder you can fix it and save alot of money.
Oct 07, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
I have a 52" Toshiba
the ballast isnt keeping the bulb lit.
Mar 16, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
264 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
