Since the outlet pipe is clogged the water is coming inside when the ac is on. Kindly let us know how to clean
Hello
This is the condensate drain line which drains humid water the a/c coil collects.
To clean you can try compressed air,blow through the pipe.Or take pipe apart and flush it out.
Have the unit off when doing this,also clean the collection pan out of debri.
Testimonial: "Thanks for the suggestion and the problem is resolved"
Periodically pour bleach into drain. You should have a primary drain, AND a secondary. Just in case the primary clogs. Usually the secondary is located somewhere very, very obvious that you cold not miss at any occassion. Outside the garage door, somewhere that you would notice water coming out.
The primary is usually hidden. If the primary clogs, the water will come from the secondary and you will notice it and UNclog the primary before the pan overflows and causes damage.
water is not coming out from our outlet pipe
