Noisy fan on Rinnai Galaxie 21 Heater
Hi
The fan on my Rinnai Galaxie 21 Unflued is very loud and I was wondering where abouts to get a new one so I can swap it out??
5 Suggested Answers
  • 53 Answers
SOURCE: rennai gas unflued heater kerosene fumes
Have it checked properly - sometimes the reg won't open fully, but the heater will still run, but with improper combustion resulting in a funny smell.
Posted on Aug 16, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai gas heater loud noise on ignition
It may be, Rinnai suggests a maximum length of about 13 equivalent feet of venting including elbows. Add 6 feet for every 90 degree elbow. If the vent is longer than this it is taxing the combustion fan motor and it will start giving you error codes and will not ignite. Remove the trim panel from behind the heater and find the flexable air intake pipe. Temporally remove it from a fitting and test the unit a few times to see if the unit starts quieter. This procedure will be taking room air into the heater for combustion and circumventing the direct vent feature of the heater, not a fix. Have you had the gas pressure tested? It gould be that! You may wish to consider relocating the heater and fire your installation contractor for putting you in this predicament, not Rinnai.
Posted on Nov 05, 2009
Testimonial: "Thanks very much. Please see comments."
  • 2557 Answers
SOURCE: i have a rinnai convector 406/516 unflued room
if you google your heater you can find the fault codes and print them off ,they will tell what is wrong and if you need a tech call
Posted on May 19, 2010
  • 4736 Answers
SOURCE: I have lost my copy
Tracey, the following is a link to the Owner's Manual for your heater. You can download and print it for future reference.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/CI_Avenger_Blaze_Dynamo_Enduro.pdf
Hope this helped you ... Cheers!
Posted on Jul 05, 2011
I require a user Manual
RINNAI GALAXIE SPACE GAS HEATER REH241EC
try www.rinnai.us and download the user manual.
Sep 01, 2014 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai convector 506tr unflued room heater won't start
Tilt switch failure is a strong possibility. They can be finicky
May 14, 2013 | Heating & Cooling
Our Rinnai convector unflued room heater won't start. Lights just flash heat never comes on.
According the the Owner's Manual for your Rinnai Convector Heater, there are 8 things, than can cause what you described. Two of which can be discounted, unless you just had the heater installed.
I have provided a link to the Owner's Manual, that you can download and print for future reference. Please pay close attention to Page # 6 -Pre-Service Check List and Fault Finding. Each problem listed has a troubleshooting solution.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/Granada252/portable_radiant_convectors.pdf
Hope this helps you to further troubleshoot and solve the problem. Please let me know. Cheers!
Jun 17, 2011 | Heating & Cooling
I have a Rinnai model 2532 Tankless Water heater. When the Bath water is turned on (which is the largest water flow for the water heater)it makes a loud vibrating sound that can be heard through the entire...
We had the same problem - the hot water would only be hot for 3 -5 minutes and shut off, then we had to turn the water off, wait a few minutes, and do it again. VERY FRUSTRATING.
Soution: The Rinnai serviceman showed me the heat-exchanger blower/fan: It was clogged with dust and moths.
Another clue: Our Rinnai was extremely noisy when the heat came on. After the fan was cleaned and replaced, it is nearly silent.
If you are reasonably mechanically inclined:
TURN THE BREAKER / POWER OFF to the unit.
The blower-fan is located in the lower central area of the unit (at least on our unit). If you draw imaginary north-south, east-west lines through the center of the unit, the fan is in the lower-left quadrant. There is a spring clamp securing the black rubber accordian-like tube to the fan. There are two screws that secure the fan to the unit. there are two plugs that connect to the fan, as well as a third air-flow sensor that should be removed. then you can look at the fan unit, as well as the grill on the underside of the heat-exchanger that should be cleaned.
My thought was to go out and get a simple bug-screen, and place it over the air-input outlet vent going outside, but the repair guy said that although it may sound good, if that screen ever gets clogged, or reduces airflow to the Rinnai, then the unit will work harder, or even shut off, giving the same problem. Also - the Rinnai pipe going outside is a pipe within a pipe - so its both inlet and outlet air.
Nov 19, 2009 | Rinnai Webstone The isolator EXP tankless...
Nov 05, 2009 | Heating & Cooling
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
