Question about LG WM-2077C Front Load Washer
The load washes for a while then shuts off on a E1 or 1E error code. And the timer doesn't seem to go on real time. I have walked away to come back several minutes later and the time on the cycle has changed only 1 minute
SOURCE: When to know if the motor is going out ?
This fix below completely fixed my LG front loader issue of the drum "freezing" and "studdering" on fill and a lot of times giving a LE (motor overload) error. Bought position sensor as described and doing a load right now!
Wolfster you are awesome...you saved me probably $200.
Definitely sounds like the position sensor is faulty. I had this happen to my WM2277HB recently. Motor would start to turn, then jerk, hum, and not move, eventually gives LE code. Powering down, all the other tips had no effect. Very unlikely that the motor itself is bad if it still turns freely. You could confirm the stator wiring is OK by unplugging it and taking resistance readings across the stator terminals of the 3-pin connector (any combo of two should be 7-15 ohms). I was able to order the part from an online electronics supplier (www.mcminone.com, P/N 6501KW2002A, description is "sensor assembly") and several other places may have it as well. You can download a basic but somewhat helpful service manual here http://136.166.4.200/contents/Laundry/WM2277.htm that has some disassembly instructions and exploded view diagrams, explains the troubleshooting mode. Don't even bother calling LG or a service tech unless it's under warranty. If you're here you probably have some basic repair skills and tools4.gif and can easily replace it yourself for about $20. My washer was about a year and a half old when the sensor went out, now it runs great again.
Posted on Dec 18, 2007
  • 1294 Answers
SOURCE: LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
Posted on Jan 29, 2008
  • 4 Answers
SOURCE: LE ERROR CODE ON LG WM-2277HW
Don't call service, they will rip you off!
See posted titled "LG Tromm WM2277HW will not spin"
Posted on Jul 16, 2008
well here is how i fixed my lg LE error.
i just replaced the main pcu and all better now. it was not the hall sensor nore the rotor on the motor or the bearing or even the power soap
it was the main computer. for about 170 bucks and took about 5 min to change out it was all done and wroking fine
Posted on Sep 04, 2008
It worked!!!!!!!!!!!!!!!This is the second time it happened to me and I had a repair man come out the first time. You need to have a shop vac with you so you can just pull the plug.
Posted on Sep 13, 2008
Hoover 500mb washing machine doesn't 'click' through the cycles
Sounds like your timer is not working correctly. I would suggest replacing it, as there isn't a way to repurchase timers.
Oct 10, 2015 | Hoover Washing Machines
Timer setting
this model doesn't have a timer. it is computer controlled.
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
FOUR HOURS TO WASH TOWELS
That is not normal. Have the control circuit board tested for continuity. Either the cycle or timer section is out of wack and may need replacing.
Feb 27, 2014 | LG WM2487H Front Load Washer
Crosley front load washer L7 code
Hi - Are you certain the error code is L7? This manufacturer does not have any L7 error codes for any washer or other units. I understand that it will not spin either; does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly.
Oct 18, 2012 | Crosley CW6000 Front Load Washer
Washer clicks, but will not start and lid will not open.
Here is a link to the Servicemanual http://www.fixya.com/support/t4120327-op_lights_up_when_hit_start
If you need to raise the washer top rom the washes base to get your clothes out see page 33 to release the washer top. Did you have any error codes to the LED display FAV6800A machine correct?
You could have a Control Board failure or a Motor Control Board failure. If you want to dig deeper into the issue let me know. If there is no error code to the display the next step (DIY) would be to read the Control Board Diag codes stored error list and see what we have.
You would need to get into Service Mode and display the Diag code list. See page 17 of the Service Manual......Rich
Feb 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a GE washer, approximately 4-5 yrs. old. The model # is WSERE526FOWW. It seems to have multiple malfunctions. First, it started overfilling. I checked the tube that goes from the tub to the pressure...
Unplug the washer.
1. Remove the front panel. Take the tube off the pressure dome on the side of the tub.
Clean the hole in the pressure dome with a piece of wire. Soap scum and lint will stop it up.
2. Check the lid switch to make sure it is mounted tightly and get good contact from the lid plunger.
3. The timer may have loose connections. Unplug and replug the timer connections.
Jan 07, 2010 | General Electric WSERE526FWW Top Load...
Frigidaire washer starts to fill with water then stops
That is not the solution.
Start the machine and immediatly press the "Start" and "Pause/cancel" button at the same time. Then you will get and ERROR code. Look on the cheat sheet packed with the machine to find out what is really wrong. That will give you the real answer.
Appliancepartssuppliers.com
Sep 20, 2009 | Frigidaire GLTF2940ES Front Load Washer
Maytag neptuneMAH9700 front load washer
Another computer generated flaw.The worst thing is alot of times that "flaw" can be a costly one
May 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
LG WM-2077C Front Load Washer Logo
21 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
