Question about RCA HD52W56 52" Rear Projection HDTV
Wave on screen top yo bottom
Wave on screen top to bottom
White band from top yo bottom of screen
Good luck with this. If it is under warranty, Sharp will take forever to do anything about it. I had this issue and Sharp wanted pictures of the problem, Pictures of the serial and model number and the receipt. I sent it to them 6 months ago and never heard anything back. If it is not under warranty, this is a major repair and it may cost more than a new television.
Apr 11, 2014 | Sharp LC60E88UN 60 in. LCD TV
Distorted Image
If bowed like )( it is in the pincussion circuit or a wave moves up from bottom to top in what you have it is a bad input filter in the power supply. The wave if there will look like a ripple moving either up or down in what can be seen on the screen.
Nov 04, 2012 | JVC AV-27WF35 TV
I have a Panasonic Quintrix F TV. About 6 weeks ago the tv screen started displaying
Rule out the signal source by seeing if same issue when a DVD etc is used.
Usually a wave like motion from bottom to top is either signal related or a problem in the power supply (wave moves from bottom to top suggests that).
If not on rear inputs (A/V) it is not the power supply.
Model number is not indicated here and might be helpful.
SD TECH
May 26, 2012 | Televison & Video
I have waves running up my screen how do i fix that
hi
depending on the waves if it is light dark bar rolling from bottom to top it may be a defective
capacitor in IF section or interference comming
for ex:defective neon sign leaky electric power transformer etc. If it is a slow moving
wave but no bars you have a defective power suply regulator and I don't suggest you try to fix it yourself
Sep 29, 2010 | Hitachi 50UX57B 50" Rear Projection...
The picture all of a sudden became blurred , color convergence is not aligned and there is a pink wave at the top left of the screen and a green wave at the bottom of the screen. When the color is adjusted...
Tv have convergence problems,it dead.Colors lines R,G,B don't aligned.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead,these parts must be replaced to solved the tv pictures covergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-43HT20 43" Rear Projection...
TV HAS BKACK AT BOTTOM AND TOP AND PICTURE WAVES
you have a fault in the power pack, ths can only be repaired by a tv engineer..
Sep 27, 2009 | Emerson LC320EM9 32 in. LCD HDTV
The top rite and leaft of my screen coners are out
Wave would indicate your loosing high voltage and the tv is nearing the end. You can tweak hv, but its a short lived solution. Good luck
Jul 09, 2009 | Philips 60PP9202 60" Rear Projection...
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
Wavy and ghosting
  1. words at top left corner have same word under it in red also on bottom of screen have seen were changing ic;s part# stk392-110 will solve problem if so what are ic;s
Apr 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
