Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Blades turn when not ingaged to turn - Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
    Scholar:
  • 110 Answers
This will be due to belt drag. There is a blade brake fitted that is supposed to push brake pads onto the pulleys when the blade clutch is 'out'. If either the pads are worn, or the spring is missing/broken/dosconnected, that will be the problem.
Posted on May 12, 2010
Husqvarns z4840 - nocks when pto is ingaged
check your blade spindles and pulleys and bearings. Also inspect the electric clutch.
Sep 03, 2014 | Husqvarna Decal, Z4824 Rh - HVP 539 11 27...
When trying to start my husquavarna 4824 zero turn mower it does nothing starter does not engage and battery is ok
Check your blade ingage switch. Sometimes they stick. You can jump start it by jumping across the solenoid switch beside the engine. I sometimes have to engage and disengage my blade switch and it starts. Hope this helps.
Sep 30, 2013 | Husqvarna Garden
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When I pull the blade lever the blades do not turn. Found that the trottle wire to pto is broken. Need instructions and a diagram on how to fix it. Thanks
just wire it back together, you don't have to worry about crossing the wires up. because it's just a hot and ground for a coil to magnitize to ingage the pto clutch.
Jun 21, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine shuts down when pedal is released, and when pto is ingaged
check your Reverse Gear engage switch and PTO (blades engaged switch), either a bad switch(es) or short in wiring indicating that you are in Reverse with the blades engaged. Is there an override function so that you can mow in reverse? Check that circuit vs. the PTO and reverse gear. good luck
Mar 17, 2010 | Garden
Not ingaging
Check to see if the belt might have come off and wedged on something under the frame. Or,,maybe a spindle could be locked-up. One more thing to check is if your deck might have a braking system on it to keep the blades from moveing it might not be disingaging.
Aug 22, 2009 | Garden
Blades ingages and then stops
It sounds like the electric pto clutch is bad. If you are looking to get a new one try www.psep.biz scroll down to bottom and click on buy oem parts. Also check www.jackssmallengines.com. I can't remember which one was cheaper. Also try doing a search you might find a cheaper site.
Good luck let me know if this helps.
roundo4
Aug 13, 2009 | Garden
What ingages blades ,blades not engage
On most riding mowers flipping the handle to engage the blade causes an idler pulley to engage the drive belt, which takes up the slack in the belt and pulls it against the drive pulleys. A few odd-balls have an electric clutch to engage the blades.
Jul 10, 2009 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
145 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
