We have a Technika copact disc player model no 88205 which we currently use to play music to customers when they are put on hold. How can I set it to contually loop and not stop as at the moment it stops once the cd ends?? Thanks in advance
  • 189 Answers
HELLO
On your player there should be a REPEAT button. If you press it once it will keep playing one track, if you press it twice there should be REPEAT ALL on the display or something similar.
This is pretty much standard for all CD players, I would be very surprised if there was not a feature like that on yours!
Posted on May 14, 2010
Is there a region unlock code for technika dvd player model TKHVD214
TKHVD214 unlock Region
I recently bought one of these DVD players from Tesco and it worked well with most of my (meagre) DVD collection.
However, it refused to play one particular DVD reporting 'WRONG REGION'.
This was so annoying and frustrating it made me briefly consider relocating to the USA <joke>, however as that was impractical I took it as a challenge to suss this badboy out.
The interwebs were no help on this one so I spent some time reverse engineering the player's firmware.
Here's the skinny:
Switch player on.
Open tray (with no disc).
On remote Press Setup.
Then press 1 3 8 9
A new menu screen will appear with some interesting data, including the currently set Region code.
Set the Region to 0.
Press 'OK' on the remote control.
Turn the player off and then back on again, using the remote control.
Sorted - thank me later!
Oct 13, 2014 | Televison & Video
Technika region code
Switch player on.
Then press 1 3 8 9
Aug 31, 2014 | Televison & Video
Is there a multiregion hack for Technika HDMISS10 DVD player ?
Technika HDMISS10 HACK. 1.open tray. 2.insert any disc. 3.press set-up. 4.from language menu,select "encoding". 5.press play. 6.select "unicode". 7.press play. 8.press set-up. 9.VERY IMPORTANT!! close draw,press "zero" fast as you can while disc is loading. "not allowed at moment" appears in top right of screen but keep pressing "zero" fast as you can and it will change to "O". player is now multi region.
Nov 27, 2010 | Televison & Video
WILL NOT PLAY A DISC
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Says no disk
Jan 31, 2009 | Mintek MDP-1815 Portable DVD Player
Code for bubble console
the codes in the book are
0768 0770 0831 0881 1097 1115 1165
Dec 09, 2008 | Alba DVD-108 DVD Player
Home burnt dvd will play on one machine and not the other. An old technika works fine, an expensive philips won't play, another new technika tells me it's the wrong disc
Newer units have protocols built into the firmware that prevent "piracy". Sometimes these new protocols will prevent a home burnt dvd from running. Hold on to the old technika as long as it will run because the newer models will not work on all of your home burnt dvds.
CH
Jul 30, 2008 | Televison & Video
50 people viewed this question
 Grubhead
Grubhead
