Question about Canon PIXMA MP530 All-In-One InkJet Printer
Check ink canon mp530
I have fitted new ink to my mp530 and am still asked to CHECK INK
by the machine.The ink is the correct one made by canon.
any help
    President:
  • 4,070 Answers
Hi! You may need to run HEAD CLEANING first before the ink goes the ink well. Try this and it may work. Hope this helps and good luck!
Posted on May 12, 2010
  • ck497 Oct 20, 2010
    how do you run a head cleaning?
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp530 printer
With the power on to machine and it turned on, open scanner lid by lifting entire top upwards(operations panel lifts up), cartridge mechanism should move to the left to allow cartridge removal, push cartridges down to remove.
here is link to user guide
http://www.usa.canon.com/consumer/contro... cut copy and paste this link will work http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid= 13368#DownloadDetailAct
Dec 07, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Ink leak?
It's not the cartridges, the waste ink is coming up thru the bottom to the exit rollers. The only fix is to have a shop open it up, clean up the ink mess and install a shield that stops the ink from coming back up when it should go to the absorbers. The new machines all have this shield and the ink tube cut back to make the ink go where it should.
Feb 21, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I haxe recently purchased a brand new canon mp530 that is still under warranty.I don't allways have the problem but often enough for it to be one.Adout 90% of the times I try to print I get an error...
I notice that you saw error message 'check ink c'. This means the printer want you to observe cyan ink cartridge. so,what happen before this message appears?. Please make sure that cyan ink is not empty. if you are sure the ink not empty,then remove cyan ink and reinstall it,else try dry clean ink cartridge contact or you may use contact cleaner before reinstall it. if you have have another cyan ink cartridge that is in good condition,compare it. if this works,means cyan ink cartridge is faulty then you need to replace with the new one. but if the problem still persist,it may caused by carriage unit or logic board problem.
Soruce: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I have put in new cyan ink cartridge but printer does not recog
are you sure you got the right ink cartidge put in? Also check if you took that piece of plastic that coverred your ink cartridge contact
Mar 20, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Chip/no chip issue for Canon Pixma MP530
the printer NEEDS ink cartridge WITH the chip
BUT, you can move the chip from the old to the new cartridge, you just lose the ability to monitor ink level....you have to visually check it from time to time
been doing it for months now... works fine, just keep a close eye on the ink when it starts to get low, can hose the printhead for that color if empty
printheads run around $55 or so - so actually, savings in ink will easily pay for a new printhead every now and then, if you screw up  :)
Oct 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Refilling mp530 ink tanks
www.PrinterInkWareohouse.com @ 866-465-7334 has solutions to most of these printer issues since that's the way they have return customers, is to have these issues bypassed!
Aug 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 U052 Error
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Feb 05, 2008 | Canon PIXMA MP530 All-In-One InkJet...
MP530- Printer issue
Install recommended ink tanks in the correct order MP500 / MP530 / MP800 / MP800R / MP830
Ink Tank Order Install ink tanks in the correct order (from left to right) CLI-8BK (Black) PG-5BK (Pigment Black) CLI-8Y (Yellow) CLI-8M (Magenta) CLI-8C (Cyan) mp500_inktankorder.gif 05sj00141_08_en.gif
Jan 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
379 people viewed this question
old marine
old marine
